helpme1234's avatar
helpme1234
RBR50 firmware update-this firmware file is incorrect
I have an Orbi RBR50 and am unable to update the firmware. The message in the autoupdate section of the router management is that the "update has failed". I have tried repeatedly to manually update and get the message, "This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product." I have tried backing down to reinstall my current version and also several intermediate versions. The older versions will start to upload, followed by the failure message. Newer versions never get to that point and result in the failure message immediately. I saw a thread describing the same issue wherein the router was purchased from an ISP; mine was from BestBuy. Any suggestions would be greatly appreciated!
  • FURRYe38's avatar
    • helpme1234's avatar
      helpme1234
      Thanks for the quick reply.
      Firmware: V2.1.4.16_1.0.0.1
      Modem: Fios G1100
      ONT: Verizon 1-211M-L
        helpme1234
        I should add that the Orbi is not functioning as the router but is in AP mode.
