Ninovan's avatar
Jul 01, 2021
RBR50 keeps dropping apple products
we have a single Orbi RBR50. We had two, but they were too close to each other and gave us OTHER problems...
Ongoing problem.  It drops every APPLE product several times a day. typically when the device has been idle for a bit. Anywhere from 5min to an hour, pick it up and you have no, or incredibly slow, internet.  Most apps say "no connection." None of the other 24 devices in the house have problems, ONLY the apple products ( 2 x ipads, an iphone 7 and an iphone 8).
we are on the current version 2.7.2.104 but have always had the problem. I keep checking in to see if someone has found a solution...
My wife wants to toss the Orbi out and get a ubiquity edge and Access point. A lot more money, but much (much) better support.  Our social club has such a config, has dozens of users at any one time, a lot of IoT stuff, and no problems... ever!!!  Not to mention much better diagnostics, traffic monitoring and more...
90 days of support for a "premium" device, netgear should be ashamed.  I know I won't buy another netgear device ever again.  I just want to get this running better so I don't keep having to turn off wifi, wait a min, and turn wifi back on on my apple devices several times a day... I really don't want to spend the money ( and time) to install a ubuiquity if I can avoid it...
  • FURRYe38's avatar
    What Apple devices do you have and what OS is on these devices?
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
    Have not see problems with my Apple devices whatsoever. iphone 12 max, mac book pro 2018, iphone 5 SE. Imac 2012.
    • Ninovan's avatar
      Ninovan
      Star
      I am connected to Xfinity via a Surfboard SB50.
      As I wrote the problem devices are 2x Ipad Pro 9.7" at the latest iOS and an iphone 7 and iphone 8, again both upto date on iOS. (14.6 on this device)
      The house is a 1200 sq.ft colonial with a basement and attic. The Orbi is in the middle of the basement, so nothing is more than 40' away from it through wood framing. We have minimal signal strength problems save a printer behind a metal filing cabinet, and that is easy to fix.  We tried putting a satalite in the attic to serve those devices. We tried both wireless and wired backhaul but had nothing but problems as it was too close to the base.
      we have used a "scanner" App to find the quietest channel, and put it on that fixed, again problems, so we have left it on Auto. Mimo is enabled.  We have LOTS of neighbors, we see 6+ networks with good signal strength...
      Again, the OTHER 24 devices, a mix of PCs, PC notebooks, cameras, printers, Echos, VOIP devices,  TVs and more have -no- problems. We routinely run 2x Zoom meetings at once along with printing and streaming all at once with no problems. Once connected we stay connected with no problem, -until- we let the apple devices go idle, then there is a 30% chance when we pick the device back up the network will be unavailable until will either power cycle the device, or cycle the Wifi off/on.  When connected, speed test returns 400meg speeds with no jitter or dropped packets...
      There is something about the negotiations between the apple devices and the Orbi that is different from all the other devices in the house. As I write this reply on one of the iPads, I have no problems. If I turn off the ipad and go for a coffee refill, when I turn the iPad back on after 5min, there is a good chance I will need to cycle the wifi to get it back.  As long as The iPad stays active I can go for hours without problems.
      My orbi is on the most current release. I have tried every tweak mentioned, and more. Even trying putting the orbi on its side as some said the signal patern is optimized for horizontal not verticle distribution... no effect.  tried moving the orbi to the middle floor, no change other than having a cord going down the stairs for a week. Tried power cycling everything, modem, orbi... works fine, until the apples go idle...
      If -any- of the other devices had problems that were repeatable I would suspect signal strength, channel, or something like that... but nothing else has problems... save ONE printer behind a metal cabinet that occasionally drops off... but even that comes back by it's-self after a minute or so.
      • FURRYe38's avatar
        One thing that is not recommended is to have the main host router in a basement. Concrete and steel inhibit good wifi signal travel. Main for 1st floor is recommended.
        Try some of these suggestions:
        Advanced Wireless Settings both 2.4GHz and 5GHz changed CTS/RTS Threshold to 2307.
        Change the CTR/RTS threshold values for both 2.4 GHz and 5 GHz (2341 and 2345 respectively), changed preamble modes to long preamble, and Set 20/40Mhz Coexistence to 40Mhz only.
        If all the other devices are not haveing problems accept for these few APPLE devices, possible problem with these devices. Something to contact Apple support about regarding there product.
  • Sounds very frustrating. There is a new firmware coming this week (2.7.3.22) but I am unsure if it will fix your issue. In any case I would recommend emailing Netgear CEO (Patrick Lo) details of your issue. He will (he did for me anyway) get someone to reach out to me from support even though I was outside the ridiculous “warranty” period. His email address is patrick.lo@netgear.com. You could also try the CTO mark.merrill@netgear.com
  • On each Apple device goto Settings -> Wifi -> then tap the "i" button.
    Then toggle off "Private Address"
    This will keep each device with a single non-randomised MAC address for your home network which should sort this
    • FURRYe38's avatar
      Nice find. Thanks for sharing.
  • Nope...
    A full factory reset would cost me several days as many of the 27 +/- devices would see it as a totally new network, even if I chose the same SSID, and insist on being reset.  some would be easy, some, like the camera on the roof,would be a real bother as it wants to be physically reset, and that ain't happening.
    I am not willing to "try" something that has no better chance of success than a power off/on reset.  I am not impressed with netgear. Actually I am impressed with their attitude towards SoHo businesses and home users vs their competition. They don't care. 90 days of support is nothing when the life of many units is many many years. Some manufactures offer lifetime support. Others 2-3 years. 90days is laughably short.
    No diagnostics should have been my first warning sign... should have returned it immediately, but it was supposed to be the best for my configuration. Ha!  No logs, no diagnostics, no feature enhancements in 2 years, no IFTTT, no VPN support, NOTHING in the way of enhancements...
    Next step, buy a ubiquity system, AP, router and controller.  If I have problems with that, I will be able to SEE what is going on...  The netgear will go in the trash... (Ok, electronics recycling).
    • FURRYe38's avatar
      Well if you reset and setup from scratch and use the same SSID name and password, ALL devices should and will reconnect. This does not take days. I done this myself and have not had to reconnect any devices that had already been connected. But your choice. Otherwise, seems to be a apple issue as these are the devices that seem to have a problem with your Orb and you only seems to be havingi. Something that a reset needs to be performed to check.
      You can try updated FW as well:
      https://kb.netgear.com/000063811/RBR50-RBS50-Firmware-Version-2-7-3-22
      Though the file for the RBS50 is inccorrect at the moment. Something hopefully NG will fix soon.
      Good Luck.
  • They "SHOULD" reconnect...
    When we went from the Google Mesh system to the NetGear system, same SSID, same Password, it was ugly.  Had to reconnect the google and force a reset on each of the picky devices while connected to the Google, and -THEN- connect the NetGear and do a new setup.  Some devices were easy to do that with... others I had to take down, bring into the basement, factory physical reset and start over... typically they were the cameras that paid attention to the MAC address not the IP... There were others...  some I had to run the factory "locate device" app, and connect that way... Each of the picky devices took time to figure out what it needed, find the app, yada yada...
    If I am going to do this, I am only going to do it ONCE more... I am not going to do this only to have it start flaking out again and THEN a purchase the Ubiquity stuff...
    • FURRYe38's avatar
      If you had left the prior router wifi system ON while you put the Orbi online and got it up and running. Once the Orbi system is online and running, all you need to do is turn OFF the prior wifi router sysetem and your devices would and should have migrated over. At most a power cycle of those "picky" devices may have been needed. Again, if you used same SSID name, PW and security modes.
    If I am going to do a new setup, I am only going to do it ONCE more... I am not going to do this only to have it start flaking out again and THEN a purchase the Ubiquity stuff...
    PS..,I noticed that no one has mentioned diagnostics.  If there were some, any, we could SEE what was happening and adjust things appropriately... If the logs showed the Ios devices dropping off and not reappearing, I could take that to apple... or if DNS was out of date, or routings tables, or some other authentication issues... but there is NO a visibility into what the Orbi is doing...
    PPS.., and then there is VPN, or actually there is not a VPN...
    So, besides dropping devices, several relatively common router features are missing... another reason to switch...
    • FURRYe38's avatar
      Ya something thats not great on Orbi systems or NG in general. Not alot of diagnostics.
      You can check statistics on the RBRs Advanced page. But this only shows connections rates between the RBR, RBS and wired devices.
      Also someone mentioned turning OFF the private addressing option on Apple products in recent iOS. May help as well. Check that blue (i) icon next to the wifi ssid name the device is connected too.
      I would update FW as well. v22 is out. The RBS .zip file has the wrong file...hopefully NG will fix that soon.
      • Ninovan's avatar
        Ninovan
        Star
        we tried private networking on and off... no change either way so we leave it so we are not tracked as much else where.
