Guapo_Apo's avatar
Guapo_Apo
RBR50 Lan Ports Not Working
Out of nowhere LAN ports on RBR50 have stopped working. WAN works great. Found this out as Smartthings hub went offline and Amazon video stopped playing. Will intermittently come back on of I reboot the router. Any ideas or is this hardware related?
  • FURRYe38's avatar
    Are ethernet cables in good condition and quality. Some cables could be a cause.
    I would disconnect all devices then connect up one wired PC and let it run. Check the connection. Then enable one of the other devices. Check for the problem. Graduate adding devices.
    Any chance you have a external Gb network LAN switch avail to test with? You could connect up all devices to it and see if router still fails.
    If anything pops up, could be a device issue or router maybe faulty.
    • Guapo_Apo's avatar
      Guapo_Apo
      Hi, yes, Ethernet cables are new and of good quality. I unplugged and reconnected all devices and it appears to have fixed the problem. If it happens again I will try your suggestions. Thank you so much for replying.
  • I have the same issue every day I have to reset my router once because LAN goes down sometimes WAN goes out too but everytime it starts with LAN
    V2.1.2.18
    Is there a Fix
    Would like a router to act like a router kind of pointless if it cant connect things
    • FURRYe38's avatar
      Would need more info your experiences.
      What is the Mfr and model of the ISP modem? built in router by chance?
      Is the ethernet cabling between modem and router and devices of good quality? Cat6 recommended. Don't mix Cat# cables.
      What ethernet devices are you connecting to the router?
      Try the suggestions I mentioned to see any changes in behavior with the router. Graduate adding devices.
      V2.1.2.18
      Is there a Fix
      • Brain29's avatar
        Brain29
        Apprentice
        modem is a Motorola SURFboard SB6141 dirrect into the orbi
        right now I have cat 6a but I have 5a and 8a on hand not sure why copper thickness or mix would make a router crash ???
        satallite is connected wireless
  • FURRYe38's avatar
    Cables could be bad or not of good quality.
    Which devices do you have connected via ethernet cable with the router?
    • Brain29's avatar
      Brain29
      Apprentice
      ethernet devices
      (unmanaged swtich) samsung smarttv
      (unmanaged swtich) harmoney hub
      (unmanaged switch) vontage phone servcie
      (2 direct 1 switch) 3 workstations
      (1 direct 1 switch) 2 raid servers (typically in idle)
      there are no bad cables the switch goes down with everything else
      There is power to all the lan ports but the orbi dose not deliever IP address or subnet
      I can connect to the router via wireless most the time 2 out of 10 times both wifi and lan drop, most the time it is just the LAN
      a simple reset fixes the problem
      the satallite will drop (it goes megenta) - but I can connect to the base wifi (most the time)
      *typically I would guess a memory leak of some kind but because it just effects LAN devices I'm not sure
      I have unplugged everything and tested the router Lan still drops if I leave one workstation in
      Dropping occures after 20+ hrs of run time
      typically after I return home so maybe 2+ hours of idle connection
      If I leave something like netflix on I haven't noticed a drop
      At first I guessed it was because my google home and chromecast(lan) but I have had them unplugged for a good few weeks and the problem still occures. I aslo rewrote all my android phones to pre 8.0
      my old asus rt56 has no issues like this (its old and slow needs to be replaced)
      • FURRYe38's avatar
        Can you remove all switches and directly connect each device directly to the router and see if any thing changes?
        What is the Mfr and model of the external swtich?
        Brain29wrote:
        ethernet devices
      Guapo_Apo
      Smartthings hub, Playstation 4 and Sony TV.  Disconnecting and reconnecting seems to have fixed the problem...
      • FURRYe38's avatar
        Wonder if there was some conflic or hang up with between these devices and the router.
        Glad you got it working. Let us know if it happens again.
