EnriqueJ
Feb 01, 2021Aspirant
RBR50 poner IP FIJA a los dispositivos conectados.
Hola buenas tardes. Necesito por favor instrucciones para poner IP fija a todos los dispositivos que conecte al Sistema RBR50, incluso al mismo Router.
Gracias
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
In inglese per favore
- EnriqueJAspirant
Refer to page 73 of the user manual for setting "reserved" IP addresses ON the RBR for your devices. You can set a reserved IP address for the RBS as well:
https://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
- EnriqueJAspirant
