kodas's avatar
kodas
Guide
May 08, 2020
RBR50 Random Lag Spikes Throughout the day
I dont know if this issue is related to my ISP or if its my Orbi router/satellite. I am connected through ethernet to my orbi router but this issue has been happening for as long as I can remember, a little over a year or so now? But basically my internet will randomly "freeze" for a solid 15-20 seconds where nothing will load, and all wifi related things wont load, but it never actually says I have no connection, they're just random lag spikes where everything returns to normal after those 20 seconds of nothing loading. Please help me find a fix to this.
Hardware version : RBR50
Firmware version : V2.3.5.30
  • plemans's avatar
    What modem are you on?
    Your firmware is out of date. the firmware the RBR50 is currently on is  2.5.1.16.
    Make sure the satellites are updated first before updating the router. You didn't put what version they're on but worth checking.
    Also, is it all devices? Devices connected to satellites? wired devices too? or only wireless?
  • FURRYe38's avatar
    • kodas's avatar
      kodas
      Guide
      Im not connected wireless Im connected through ethernet to my router, and I disabled Daisy Chain but I dont know how to disable the other things you mentioned like Armor, Circle, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes.
