PaulBrassington's avatar
Jul 26, 2018
Rbr50 satellite to satellite
Just bought the RBR50 router and satellite but our cabin at the end of the garden is too far away. So I have bought a second satellite, please advise how to connect the second satellite to the first satellite to extend the range.
Warm Regards
Paul Brassington
  • FURRYe38's avatar
    Should be able to enable Daisy Chain on the router and this should set up the satellites to piggy back of one another...
    • Pfredd's avatar
      Pfredd
      Guide
      Where is the Daisy Chain setting?
      I can't find it on my CBR40
      • PaulBrassington's avatar
        PaulBrassington
        Hi   All,
        This worked for me:
        http://orbilogin.net on   my PC, then Advanced tab, Advanced Set Up, Wireless Setup then click Enable Daisy Chain  Topology
        Connect the first satellite to the Router
        Put the second satellite in line with both (a straight line between all three , this stops the second satellite to connect to the router) then turn the second one on, click the first satellite sync button and then the second satellite sync button.
        Open the app on   my phone and see the  network  map to ensure they are in line.
        Hope this helps you  all.
