badler4's avatar
badler4
RBR50 slow wired speeds
I check the speed test on the Orbi app, and I'm getting 600-750Mbps (paying for 912Mbps from Spectrum).  I have a wired connection, Cat 8, from my ethernet port on the Orbi router to my laptop docking station.  Run a speed test, and I'm getting no better than 225Mbps.  What am I missing?  Did a factoy reset on the Orbi, no changes.
  • FURRYe38's avatar
    Can you connect your laptop directly to the RBR and by pass the dock station?
    Do you have a different wired PC to test with and compare results?
    Use Ooklas installable speed test app for Windows...
    do not use the app
    try another web base spped test site
    • badler4's avatar
      badler4
      speedtest.net still giving my 250Mbps approx.  Wired it directly to my laptop (no dock), no improvement.  ISP is Spectrum, and modem model #is E31T2V1 (Charter).
    • badler4's avatar
      badler4
      directly connected now from orbi ethernet port to laptop.
      • FURRYe38's avatar
        Is Armor, Circle or Traffic Meter enabed on the RBR?
  • Sorry I’m new to this.
    I’m having a similar problem. Did you ever get this resolved?
    • FURRYe38's avatar
      How are you speed testing?
      What devices are you using to speed test with?
      Browser speed testing or app speed testing?
      • badler4's avatar
        badler4
        For me, I think it came down to my hardware.  Laptop was a bit older, so ethernet port was not able to support the higher bandwidth.  That said, I've moved on from this router and have a new laptop.
