Liquidcore's avatar
Nov 16, 2019
RBR50 unable to handle gigabit connection?
Hi there, I recently purchased the RBK50 to improve the WiFi range in my house and have configured the RBR50 as a router rather than an AP but it seems to be having trouble handling my gigabit connection. Firmware is 2.5.0.38.
My connection is 900/500, PPPoE, vlan 10 tagging. The ONT is a Nokia G-140W-C.
Using the internal Speedtest app in both scenarios:
ONT -> RBR50 - speeds around 400 down/300 up
ONT -> Fritzbox -> RBR50 (AP mode) - speeds around 900 down/500 up
This suggests to me that the RBR50 cannot handle the routing of a gigabit connection.
Has anybody had similar experiences?
Thanks!
  • Retired_Member's avatar
    Retired_Member
    Please do a search.  Lots of posts about  2.5.0.38 and it’s problems
    • Liquidcore's avatar
      Liquidcore
      Star
      Thanks for the response - I had read quite a few threads before posting but unsure if any match my problem.
      I guess another question would be whether anybody has a gigabit connection being routed fine using the RBR50 with PPPoE? And if so, what firmware version they are on.
  • FURRYe38's avatar
    The  version of FW isn't the problem as this has been on going since before v38:
    https://community.netgear.com/t5/Orbi/Orbi-RBR50-is-not-supporting-900Mb-on-the-WAN-to-LAN-test/m-p/1770816/highlight/true#M64990
    Thanks!
      Retired_Member
      Yes it is.     Admit the truth
      was the the network ever working?
      why not change the firmware?
      Thanks!
  • Thank you for the replies.
    Apologies for my ignorance but does testing the speed directly from the in-built Speedtest app count as WAN to LAN? I feel as though the RBR50 cannot handle gigabit WAN?
    • FURRYe38's avatar
      No, the built in speed test is based on the WAN side only connection. Not actual WAN to LAN thruput process.
      The best way to test to see if WAN to LAN is fully working is using a wired PC connected to the RBR and use Ooklas speed test app for Windows or Mac.
      So with my RBR50 behind a RBR850, I am seeing faster speeds. Something I can't reproduce when the RBR is alone with just two PCs speed testing. I feel this is something in FW. Going back probably a few versions at least. Not sure how far back as I've only had my RBR50 for about 9-12 months. I can speed test my RBR850 with just two PCs and it tops out at over 900Mbps. If I put the RBR50 in same test configruration, it tops out at just over 400Mbps. Though if it sits behind the RBR850 thats working as the main host router, the RBR50 in router mode, double NAT, it seeing upwards of 700Mbps. Very odd behavior.
        Liquidcore
        Star
        Thanks for the reply yet again and confirming my suspicions :)
        I wonder if it is because the connection is PPPoE and the RBR is struggling with the gigabit WAN? If that's the case then I might just have to use it in AP mode instead, which is a bit of a shame.
  • I've been experiencing basically the same exact situation.
    Edited to add: ...but I'm using the 2.3.5.30 fw
  • FURRYe38's avatar
    Liquidcore and Mitch2k2 and anyone else not seeing near 900Mbps with there Orbi routers with wired speed tests. I was contacted by NG support today. There looking into this. Asked for some debug logs and configuration of my test software.
    For those if you who are having problems, can you please log into the following web page on the RBR and enable WAN/LAN Packet capture then start the debug capture.
    http:\\192.168.1.1\debug.htm
    When you start the debug log capture, access routers UI and run speedtest (Advanced TAB > Setup > Speed Test). Once done, you can save the logs.
    I would also re-start the WAN/LAN packet capture again and start debug logs then run a speed test with Ooklas installable speed test app for a wire connected Windows or Mac PC. Once done, you can save the logs.
      • FURRYe38's avatar
        Post them up in the cloud, i.e. dropbox, googledrive or something to host your .zip files. Send the shared access URL link to Blanca_O
        Mitch2k2 wrote:
        To whom/where should we send these logs?
