Batdoc31's avatar
Batdoc31
RBR50 with 2 Hardwire RBS50 and switch Problem
All,
About to give up despite the large investment Ivemade in Orbi. Originally I had 1 RBR50 and 2 hardwired RBS50 and then 2 RBW20 plugin satellites for a large home. Ive replaced every bit of hardware with a new one which still recreates the problem which is once I connect the switch (hardwired directly to the RBR50 I instantly get download speeds on WiFi from 350Mbps to 50-10Mbps. Wasted several hours with “tech support” over the weekend which was completely useless.
Any thoughts?? On my last leg here....
Have tried isolating the satellites, connecting them wirelessly instead of wired and nothing helps. The only thing Ive noticed is that for whatever reason one of the Ethernet ports on the back of the router is putting out 100 while the other 2 put out 1000? Also tried new router and same issue.
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
    What is the Mfr and model# of the ethernet switch if one is in the configuration.
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
    What WPA security modes are you using?
    Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
    Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
  • I didn’t get with which configiration you see the reduced speed issue.
    You said that you get same results with wired and wireless Satellites. With which configuration do you get the full 350 Mbps speed?
    • Batdoc31's avatar
      Batdoc31
      LATEST Firmware is the most up to date for RBR50 and satellites. Whether hard connected (Ethernet backhaul) or wirelessly connected I get the fast speeds. In either scenario everything starts to fail as soon as I connect the switch reducing my speeds to 5-10Mbps
      • ekhalil's avatar
        ekhalil
        Master
        Batdoc31 wrote:
        ........ everything starts to fail as soon as I connect the switch reducing my speeds to 5-10Mbps
        1. What switch do you use?
        2. Do you connect it to the Router or Satellite?
        3. What other wired devices do you have attached to Orbi nodes?
