ChinoMorales's avatar
Oct 03, 2019
Rbr50
I'm using Orbi RBR50, router with two satellites and we are changing our internet provider, do I have to do a "New Setup" once I have the new provider? I will be using same modem though.
Thanks a lot.
  • Just power OFF the modem when you change ISPs for 1 minute then back on.
    Thanks a lot.
  • plemans's avatar
    Thoretically no.  I would recommend it however. It might work great once the new ISP provisions your modem but it might have issues. Just take a backup of your configuration so you can restore it once you've got the new setup provisioned.
  • FURRYe38's avatar
    Thanks a lot.
    • michaelkenward's avatar
      michaelkenward
      ... and while you are doing that, also turn off the Orbit router and then turn that back on when the modem is up and connected.
      • ChinoMorales's avatar
        ChinoMorales
        Tutor
        I waited for the new ISP tomsend the signal to my modem as did as suggested by you, all working fine now, thanks again.
