BHHJR
Apr 13, 2018Tutor
RBS 50 fails speed test
My Orbi keeps saying it’s failing to run a speed test and reboot the router. I have done it several times to no avail.
- st_shawMaster
I believe there is a problem with the Ookla server used by the Orbi app for the speed test.
If you want to run a speed test, just use a speed test app or website on your client device.
- BHHJRTutor
Thanks. I have run the Ookla speed test which is fine. So looks like the speed test in Orbi has a problem, not my router.
- GerryJ99Aspirant
Same here. Speed test works using Ookla app on iPhone and iPad (tested with 3 different servers), doesn’t work on Orbi iPhone/iPad app or web. Orbi doesn’t give option to change Ookla server, just says if problem persists try rebooting your router (which I did to no avail).
