tgarvey's avatar
tgarvey
Tutor
Mar 18, 2019
RBS20 FW update
My package of an RBR40 and three RBS20s would not automatically detect and run the 2.3.0.28 FW updates when I logged in via my browser.  I downloaded the two firmware files and first upgraded the RBR40 successfully.  (Yes, I know now you're supposed to do the satellites first.)  The RBS20 update has failed several times, with a message saying I'm using the incorrect file.  I've re-downloaded it several times and get the same result.  Any suggestions?
  • PS:  I also read about the need to first update to 2.2.1.212, but I can't find that version on the NG website.
    • plemans's avatar
      What version is the RBS20 on right now? have you tried updating to the 2.2.1.210 thats on the website and upgrading from there? I didn't see the .212 on the website either.
  • FURRYe38's avatar
    You can manually download v28 for the RBS and directly update to that version FIRST. There isn't v212 for the RBS20.
    Then update the RBR40 to v212 then v28 lastly.
    https://community.netgear.com/t5/Orbi/New-NetGear-Orbi-20-40-Series-Firmware-Version-2-3-0-28/td-p/1714639/jump-to/first-unread-message
    Factory reset and setup from scratch.
    • tgarvey's avatar
      tgarvey
      Tutor
      Two of my three RBS20s have now updated to 2.3.0.28 without any further action by me, so I assume the auto-update function worked for them.  Running the "Check" function still does not detect an update for the third one, but I'll wait to see if that one catches up.  The process seems pretty random, though I assume there's something behind the scenes that accounts for this.
      For now I'll wait and hope that the upgrades cure the need to reboot the RBR40 at least once a day.
      • FURRYe38's avatar
        Or you can manually install the FW files as well.
        Good Luck.
  • FURRYe38's avatar
    There should be a .img file after unpacking the .zip file. This is the FW file.
    Check your zipper program to make sure it's unpacking the .zip file correctly.
    • tgarvey's avatar
      tgarvey
      Tutor
      Yep, I've been using the img file, and I've downloaded & extracted it about five times now, using the same zip app that suucessfully extracted the RBR40 file.  I'll try it again in a day or two if the auto-update still hasn't gotten the holdout done.
      BTW, do you know if you still need to leave Daisy Chain on?
      Thanks for your suggestions.
      • FURRYe38's avatar
        Yes thats the correct file for the RBS.
        Depending upon if you have the satellites connected via ethernet or wirelessly connected and placed in a linerar line out from the router or in a star formation with the router, would dictate if Daisy chain is needed. Wired ethernet or Star formation, Disable DS.
  • FURRYe38's avatar
    Good to hear. Let us know how it goes.
    If you need to, try a factory reset and setup from scratch.
    Good Luck.
