Shirosen
Apr 07, 2018Guide
RBS50 Disconnecting
My Orbi RBS50 (satellites) has been disconnecting consistently, it would disconnect and a few seconds later turn blue. Thinking that the issue would resolve itself, I've let it continue for about two...
May 03, 2018Guru - Experienced User
Try using just the router itself?
- ShirosenMay 05, 2018Guide
The Orbi router itself is working fine, it is the connection between the router and satellite that is the problem. The reason why I bought the Orbi, is not to be tied down by my router since it is in a difficult location to reach.
