Shirosen
Apr 07, 2018Guide
RBS50 Disconnecting
My Orbi RBS50 (satellites) has been disconnecting consistently, it would disconnect and a few seconds later turn blue. Thinking that the issue would resolve itself, I've let it continue for about two...
May 03, 2018Guru - Experienced User
Try using just the router itself?
Shirosen
May 05, 2018Guide
The Orbi router itself is working fine, it is the connection between the router and satellite that is the problem. The reason why I bought the Orbi, is not to be tied down by my router since it is in a difficult location to reach.
