jbrown316
Nov 04, 2020Apprentice
Access control issue/bug with Orbi 2.7.1.60
Since I upgraded to the latest firmware, the Access Control feature in Advanced...Security in the UI doesn't work properly. When I turn access to certain devices off, it is also turning off access t...
vajim
Feb 07, 2021Master
Stev3D wrote:jbrown316 , I don't know if anyone mentioned this to you or not, but if you aren't using Armor or the other add-ons from Netgear, and are just limiting access to your network through a Byzantine password and Access Control (like me), you might want to downgrade to v2.6.1.40, the other "fork" in NETGEAR's software path. I had a hell of a time with the v2.7, and things got much better when I went back to 2.6. I'm running v.2.6.1.40 and have not been a victim of un-solicited upgrades.
But a word of warning: Don't use the iOS Orbi app to manage accesses -- it seems to screw up the device database in the router (something I learned once the hard way, and foolishly repeated that mistake a week ago). I've reported the issue.
More of what I've been saying all along
these firmwares come out without proper testing and trial
this is been going on for a long time The ones that suffer are those that are told or they feel they MUST upgrade, to include those who fully support this madness and slam those who oppose
BoilerPlate
Feb 08, 2021Apprentice
Vajim's lack of knowledge and experience, is your mileage may vary. >vajim. User beware. :smileysad:
Historical posts prove it:
https://community.netgear.com/t5/Orbi/Orbi-RSR50-firmware-2-5-1-16/m-p/1903734/highlight/true#M90556
https://community.netgear.com/t5/Orbi/Problems-with-new-Orbi-RBK53-setup/m-p/1876257#M85028
https://community.netgear.com/t5/Orbi/Constant-VPN-reconnecting-since-upgrading-to-firmware-V2-5-1-8/td-p/1879290/jump-to/first-unread-message
https://community.netgear.com/t5/Orbi/Netgear-drops-the-ball-again-RBR50-on-FW2-5-1-8/td-p/1876302/jump-to/first-unread-message
https://community.netgear.com/t5/Orbi/Orbi-RBR50-was-working-amp-changed-modem-now-not-working/m-p/1887710#M87429
https://community.netgear.com/t5/Orbi/Orbi-RBK50-Speeds-Drop/td-p/1891090/jump-to/first-unread-message
https://community.netgear.com/t5/Orbi/dropped-bandwidth-on-Orbi-RBR50-with-cm1000-modem/m-p/1901910#M90201
https://community.netgear.com/t5/Orbi/Orbi-RBR50-bricked-during-update-to-2-3-5-30/m-p/1897073/highlight/false#M89235
Sad that he has to spread false and inaccurage information and bager and troll others that are just providing help to others. Must have a sad life.
:smileysad:
