Mykd's avatar
Mykd
Satellite issues
Hello, I’ve added two refurbished satellites recently. I have updated their firmware, and when I access them on the orbilogin.com they both show as operating with good connections . However they as well as my original mesh satellite show up as disconnected on the Orbi app. All three satellites also keep dropping their connections. Any recommendations on how to resolve this? Thanks
  • plemans's avatar
    What satellites do you have?
    What firmare is on the router?
    What firmware is on the satellites?
    What modem/gateway are they connected to?
    What size is your home?
    What are the interior walls made of?
    • Mykd's avatar
      Mykd
      Hi, thanks for asking.
      Satellites are
      2 RBS50v2 and 1 RBS50
      The firmware on the router is  V2.7.3.22
      The firmware on the satellites is also 2.7.3.22
      We have a 2000 sq foot home on one level.
      Walls inside are standard plaster.
      Previously, before adding the two refurbushed satellites, the original satellite worked very well. It was only after adding the new refurbished satellites that it stopped working.
      I've tried disconnecting the satellites on the main web browser controls, then resetting the satellites. I've tried to reconnect one unsuccesfully; it now apprears as a device and not a satellite.
      • plemans's avatar
        Are you connecting them daisy chained or star configuration?
        Daisy: Router------>satellite----->satellite
        Star: satellite<--------router--------->satellite
