Fitzcal's avatar
Fitzcal
Tutor
Jun 25, 2017
Satellite Keeps losing connection
Orbi worked great the first week. Since then it drops connectivity daily along with the satellite.
  • Same here.
    Satellite bricks.
    Can't access web-admin. Can't connect wifi.
    I got new firmware V1.12.0.14. and not I'm testing.
      • DarrenM's avatar
        DarrenM
        Sr. NETGEAR Moderator
        Hello Doug
        Have you logged into the Web UI and checked the attached devices? can you see the satellite?
        DarrenM
  • I seem to have this issue too, I think? System is up but in the phone app the Satellite doesnt show, but it did the first day?  I am running current firmware version. purchase 6-23-17 at Best Buy.
    firmware ~ RBR50 / RBS50 Firmware Version 1.11.0.20
    ISP Comcast - HD Package 150mbps
    2,200 sq ft ranch
    Satellite and router about 45 ft apart, one wall.  I need a way to test and verify constant connectivity.
    • ArtLee's avatar
      ArtLee
      Apprentice
      I've been having the same problem: satellite disconnecting from the router. Two walls in between. I have concluded this doesn't work for me.
  • My local netgear branch(S.Korea) provided a beta firmware for this problem. - V1.12.0.14
    My Orbi works great over 32h+ so far.
    Seems newer firmware will help.
    • ArtLee's avatar
      ArtLee
      Apprentice
      I have had to move my satellite twice because it keeps disconnecting the backhaul, I guess. If this current spot fails, I'll return the Orbi kit, You must admit, though, that 32 hours isn't long.
      • Doug-48051's avatar
        Doug-48051
        Luminary
        From what I read.... the back haul is initiated by the router... so i moved the router to the center of the house.... and the sat to the further point. But only way I could do this is the 2 network jacks build into my house.
        But, you are correct, if it doesnt suit my needs I will send it back also.
        Doug G
        FW version: RBR50 / RBS50 Firmware Version 1.11.0.20
        OS: Windows 10 Creative
        ISP Comcast at 150mbps
        14 connected devices.
        2,200 sq ft ranch open floor plan.
        Router and Sat. about 45 ft a part. (two walsl)
