abcchana
Nov 02, 2019Aspirant
Satellite office RBR50
Hi all, my satellite of RBR50 is sometimes offline / discount but the main one (mother) is still online.
I have diabled any power saver setting. And the discount happens with no pattern
Is it due to the hardware problem? I still get warrant. Could I know it is possible to exchange the new satellite? and now is the process? Coz my call/help service were already expired.
Many thanks
Many thanks
- abcchanaAspirantTo clarify, the distance btw the mother and satellite is just a wall. Very close
- Retired_Member
what firmware do you have?
- abcchanaAspirantHi VAjim,
I am still checking , thanks a lot
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Has a factory reset and setup from scratch been performed since last FW update?
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settingsI
Many thanks- Retired_Member
Too much fur bad firmware
- abcchanaAspirantHi Furrye38,
Thank you for your detailed comments.
Could I ask below?
1.Try enabling Beamforming and MIMO(MIMO may or maynot be needed)
How to do?
2, how to manually set and fix the channel with Orbi?
Many thanks ! Have a good day!- FURRYe38Guru - Experienced User
abcchana wrote:
Hi Furrye38,
Could I ask below?
How to do?
Under Basic tab/Wireless settings.
A factory reset maybe needed to ensure any recent FW updates are installed correctly and any mis-configurations are cleared out. After setting up, you can do a back up configuration to file for safe keeping. Under Advanced tab/Backup.
- abcchanaAspirantAlso, could I ask what is the point to have a factory reset?
Thank you- Retired_Member
Thank youYes....waiting to hear the answer to this
