thebadpete's avatar
Jul 03, 2020
Should I upgrade my firmware? I am on 2.3.5.30
Subject says it all. I have been on 2.3.5.30 and resisting to upgrade. I manually splitted my 2.4/5GHz channels so they have different SSID's, and I disabled auto firmware updates.
Should I stay with 2.3.5.30, or is there any newer firmware that is as stable as 2.3.5.30?
  • CrimpOn's avatar
    CrimpOn
    Stay on 2.3.5.30.  I have two Orbi's.  The one in my house is currently on 2.5.1.16 and "works fine."  However, I left it "stock".  The one across the country (where I have been unable to visit) remains on 2.5.5.30 and "works fine."
    We have sort of a mantra, "If it ain't broke, don't fix it."  Unless there is "something wrong" with your Orbi that the release notes claim have been addressed, leave well enough alone.
    Sorry to be strident, but you did ask.
  • FURRYe38's avatar
    If you do choose to upgrade, manually download the FW files and install them with a wired PC and web browser:
    https://community.netgear.com/t5/Orbi/RBR50-RBS50-Firmware-2-5-1-16-Update/m-p/1897955/highlight/true#M89460
    Always upgrade the RBS first then the RBR lastly.
    Good Luck.
  • Still on 2.3.5.30 also.  Tried 2.5.1.8 but the device icons are cartoonish and it still doesn't fix what i want - readyshare file sharing on the router USB port and a faster web server for the admin UI.
