packgreen49's avatar
packgreen49
Signal Strength
On the wireless setting.  Why am I getting a Stronger setting when I am 30 feet from the router than right by the router.  Something like 100 at the router and 300 about 30 feet from the outer?  My service is 500.
Ron
  • FURRYe38's avatar
    Signal propagation depending upon buiding materials, surroundings and noise and interference will be a factor. Usually strong signals near the source can be over powering to connected devices. Getting distance will cause the signal to improve for the device. Most distances starting are around 6 feet from the RBR. 30 feet seems to be the sweet spot for RBR and RBS wifi over lap connections so RBS at 30 feet is a good starting point and beyond. Depending upon building materials of course.
      • FURRYe38's avatar
        Is the Orbi system operating in Router or AP mode?
        Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
        Is your ethernet adapter connecting at 100Mbps or 1000Mbps to the back of the RBR?
  • CrimpOn's avatar
    CrimpOn
    There is a difference between "Speed" and and "Signal Strength".  Signal strength is always measured in dBmv and is always a negative number.  The lower (more negative) the number, the lower the signal.  There are programs for laptops and smartphones which will display the actual signal strength of the various Orbi routers (2.4G user, 5G user, 5G "backhaul")  I, personally use WiFi  Analyzer on my Android phone and Galaxy Tablet.  Signal strength will always be lower the farther away the device is from the Orbi radio.
    Download speed may be related to signal strength, but the relationship is not obvious.  As long as the connection between Orbi and device is "good enough", the download speed will be a function of the ISP bandwidth and the Orbi internal processing capability.  There are all sorts of posts remarking on the Orbi's inability to keep up with today's faster bandwidth.  The Orbi product was designed in 2016, when 100mb connections were rare.  Today, people routinely get gigabit connections, and the Orbi simply cannot process packets that fast.  The new Orbi WiFi 6 product is supposed to handle much higher connections.  (It also starts at $800 for a set!)
    • packgreen49's avatar
      packgreen49
      The problem was the maximum I can receive is 100.  Anything over 100 didn't matter.  The card maximum is 100.
      • CrimpOn's avatar
        CrimpOn
        The "card"?  The modem?  The device you were measuring speed with?  (I understand the mystery is solved, but it would give me "closure" to understand.  Thanks)
