nabeelm
Mar 31, 2020Follower
Slow wifi speeds Orbi RBR50
Hi Guys!
My first post, so not sure if I am addressing this correctly or not! But Ive started to experience slow wifi speeds over the last few weeks.
I have Virgin Media 350mbps using SuperHub 3 as Modem mode. However on the Orbi RBR50 Im getting speeds of upto 70mb. (Being right next to the Router, using Macbook pro2018)
Intially I thought the issue was with VM, so connected SuperHub3 Router mode and speeds went upto 280mb. (Same device and same distance)
I keep hearing about Advance Wireless Settings, but I was hoping if anyone could help here? Ive had the RBR50 since 2017 and never had issues before. Do I need to downgrade firmware? And if so (how?)
Many thanks!!!!
RBR50 Firmware v2.5.1.8
- Retired_Member
if you'll do a search, you'll see that many have had problems Firmware v2.5.1.8
your best bet is to revert back to your previous version and STOP performing manual downloads
- tspoonAspirant
How do you revert back to the previous Firmware to see if it corrects the issue
Just download the prior version of FW files and manually apply them.
You should try a factory reset and setup from scratch before downgrading. This has helped others seeing problems.
Can try voxels FW aswell:
tspoon wrote:How do you revert back to the previous Firmware to see if it corrects the issue
Is your modem bridged? If your modem has a built in router, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
https://community.netgear.com/t5/Orbi/Orbi-model-RBR50-keeps-dropping-connection-during-Zoom-calls/m-p/1874136/highlight/true#M84647Has a factory reset and setup from scratch been performed since last FW update? Try this before downgrading.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
nabeelm wrote:Hi Guys!
Many thanks!!!!
