Wakey's avatar
Wakey
Star
Nov 02, 2019
Speeds have plummeted after latest update.
New to Orbi and have been delighted with its speed. I have 500 internet and all over the house was getting very fast speeds and always without exception full upload speed of 35.
As soon as I’ve updated the firmware it has plummeted in speed. You can see the exact moment my firmware was updated on the Speedtest history, and even upload speed seems halved.
How can Netgear release a firmware update that trashes the product?
Any ideas. I bought this system as consumer friendly with no rigmarole, will resetting it and all the hassle that requires even work? Why should you have to do that?
I see others are reporting similar issues and resetting did not work for them and they have rolled back the firmware. I have no idea how to do this and only use the app- my web browsers (Chrome and Safari) cannot for some reason connect to it on my Mac (could not when I bought it a few weeks ago).
Very sad as I had a great system, now it is trash.
Thanks everyone.
  • OK so I worked out how to backdate the firmware and did it only on my 2 satellites so far. Suddenly my speeds are straight back to where they were (I also noticed the ping drop back down a couple of points, it had gone up post latest firmware).
    So there is something definitely broken in this firmware.
    Question is, do I also roll back the main Orbi Router firmware or leave that on the latest and the satellites on the last version?
    Thanks
    • Wakey's avatar
      Wakey
      Star
      Further update, rolled back the router firmware so they are all on the same.
      All previous speeds and throughput is now immediately restored.
      Morale or this story- never upgrade stable Netgear firmware, I will not be doing it again.
      • Gregron's avatar
        Gregron
        Star
        Glad you figured out how to roll back the firmware! Happy your system isn’t garbage anymore!
  • FURRYe38's avatar
    Try a factory reset and setup from scratch if you see this problem again after updarting FW. Some have not done this and not given a full reset and setup a try. it does work and helps in these cases where users upgrade and see bad behavoir. I know a reset shouldn't be main stream however for some cases, it needs to be give a chance. I saw no speed loss after upgrade to v38 and had great operation. However I alwaya manually update and factory reset and start out fresh. Just works. Others as well:
    https://community.netgear.com/t5/Orbi/ORBI-RBK50-RBS50-Tips-Tricks-Hidden-Secrets-etc/m-p/1818889/highlight/true#M74523
    https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
    https://www.youtube.com/watch?v=ePZSc7vnRlQ
    Good Luck.
    Thanks everyone.
    • Orbi-Roc's avatar
      Orbi-Roc
      Luminary
      Same here FURRYe38 . A factory reset after each firmware update has kept me safe from all those issues I read about. Just curious Wakey -- did you check your log? Just wandering if perhaps something else is getting in the way and causing your system down to crawl.
      • Wakey's avatar
        Wakey
        Star
        I didn’t check any log, but it slowed when the new firmware was installed, and went back to how it was when I rolled it back, so it seems to be the firmware. It also seems to be the firmware on the satellites from the fact it went back to what it was when the satellites were rolled back before the router itself. Router has always showed 500+ speed when doing a speedtest on it even after the dubious new firmware was installed, so it was either the backhaul or the wireless performance that was degrading under new firmware.
        I’ve seen a lot of reports across the internet of the same thing, so for some reason this firmware is affecting a lot of people. Have you got a very fast internet connection of plus 200 because the reports seem to be coming from those people?
