poswald's avatar
poswald
Guide
Nov 18, 2018
Streaming from network devices stops due to constant DHCP lease renewal?
I've had nothing but trouble with the orbi system but mostly we have battled to a stalemate. The one remaining thing I can't tolerate is constant dropping of streams from Apple TV, Amazon Fire sticks and PS4's.
It seems to be caused by reissuing IP addresses. For example I constantly get ‘Lost internet connection’ on the 4th gen Apple TV even if it isn’t playing anything. When It's playing music then it drops the stream and stops. Pressing play immediately starts it again without delay.. it's not an internet problem, it's a local network issue. It’s accompanied by a log entry on the Orbi:
    • [DHCP IP: 10.0.0.8] to MAC address xxxxxx, Sunday, October 14, 2018 09:59:41
 This will happen about once or twice an hour, sometimes multiple times within 10 minutes where nothing else on the network is changing. These errors are all over the logs for just about every device on the network. Assigigning dedicated static ip's to devices doesn't help. Disabling every sattelite and just using the base station doesn't help. Signal is reported as strong by Apple TV and a wifi scanner near it.
I have the following now but the problem was there in previous releases as well:
Router RBR50 V2.2.1.210
Satellite RBS50 V2.2.1.210
Satellite RBW30 V2.2.1.204
Can anyone here think of any way to troubleshoot this or do I have to throw it away and buy something else? I'm kind of done with dealing with a system that has both rampant bugs and very little debugability.
  • I had similar issues, that I found out -after too much troubleshooting- caused by my wired speakers that are part of a mesh audio system.
    What wired devices do you have connected to your system? Do you have wired Sonos to your system?
  • FURRYe38's avatar
    What is the Mfr and model# of the ethernet switch if one is in the configuration.
    MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
    For wired back haul:
    Set up IP address reservations for each satellite and devices on the router as you add them to the router. The satellites need to be set up via wireless first. Then connect 1 satellite at a time to the ethernet LAN cable. Wait 5 minutes and the top led on the satellite should turn on BLUE. Set up an IP address reservation for the 1st satellite. Continue to do the same thing for the 2nd satellite. Then follow up with your devices.
    Modem Combo Units:
    Couple of options,
    1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
    2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
    • poswald's avatar
      poswald
      Guide
      Thank you for the replies.
      Only a Synology NAS connected to the RBS50 sattelite but it doesn't seem to matter since it happens even if both sattelites are turned off. Even the NAS which has a wired link to the satellite and I’ve given it a static IP gone through times where it reports “link down, link up” every few minutes.
      I'll have to look this up when I get home. It's a Japanese model since I live in Japan.
      No switches.
      *sigh* yeah I was afraid that this would be the recommendation. I've tried toggling a bunch of these on/off over the many months I've been troubleshooting this. I haven't tried IPv6 or 20/40Mhz Coexistence yet... I did do a wifi scan and see the networks switching between 20 and 40 but it didn't seem to correlate wtih the DHCP crazyness so I left it. I do want the system to be daisy-chained since the space is long and the main router is at one end.
      This is something I also considered but haven't really wanted to get into. The modem is pretty janky and the UI is only available in Japanese. Kind of a pain to configure or fix if I make a mistake. I may try it out if it comes to this but for the record the Orbi is replacing an Apple Wifi router that never had any issues with this modem.
      My biggest complaint is with the seemingly very low quality control on updates, and complete lack of visibility into the state of the system or misleading data where it exists. I'd like a better source for information on why the modem reissues IP's.
      • FURRYe38's avatar
        Let us know about this modem. Just checking to see if it's got any built in router and wifi. These modem can cause problems.
        If you do want the system to be Daisy chained, then besure the Satellies are in a linear line out from the base router and from each other. Then if your on v210, uncheck Daisy Chain, this should actually enable Daisy Chain for this version of FW.
        You'll need to contact your ISP about what happens on your modem and IP addressing. They control the modem and IPs up to that point.
    Do you notice that those devices change from 2.4GHz to 5GHz or vice versa when this interruption happens?
    I noticed that some of my devices suddenly decide to move between the two bands back and forth, together with this change there will be internet interruption for a short period and a DHCP message like the one you mentioned in the Logs.
    • lizabny's avatar
      lizabny
      I am seeing the same exact issue - with constant dhcp ip issuing and clients continuously dropping from the network. And my newest macbook pro willl not reconnect, and occassionally other macbooks, iphones and ipads suffer the same issue. We don't have many heavily used, non-ios clients, but my canon printer hasn't been able to be used without restarting it, either. I've also tried all sorts of various options and placements, and am stuck, and frustrated because it disrupts business video calls and demos all the time! We have a 5000 sqft home and have tried R-S-S daisy chain and S-R-S configurations, with no improvement. I'll have a day or two with no issues, and then mornings like just now where it dropped almost a dozen times within an hour.
      I do notice that sometimes I'm connected to 2.4 and sometimes 5, though I don't know if it constantly flip-flops back and forth. I'll watch for that. Maybe I'll try to force the 5 connection only either through the clients or the router, and see if that stabilizes things.
      • FURRYe38's avatar
        What FW is currently loaded?
        What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
        If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually for R-S-S.
