superbovine's avatar
superbovine
switching requirements for ethernet backhaul
Hello,
I have 2 satellites (RBS50) and I like to setup an ethernet backhaul to RBR50.
When I connected the satellite directly to the same switch as RBR50, it establishes and ethernet connection. However, once I moved the satellite to a different room on a different connect switch it does not work. I believe there are 3 switches between the satellite and RBR50.
Is this supported? Is any specific specification requirements with the switches?
