Bayamon62's avatar
Jul 20, 2018
TP-link switch sg-108 wont connect to internet
After connecting my Orbi RBK33 ( rbr-40 router) my TP-Link TL-SG-108 ethernet switch will not connet to internet ,i have a ethernet cable from the orbi to the 8 port switch and nothing connected to it can connect the internet ( it was working fine when connected to my ASUS RTu68)  , i can connect the same cable straight from the ORBI router  to my laptop and access the web , but once i connected to the 8 port switch nothing happens nothing can connect to web , is there a setting i need to change on the router  to make the switch worrk ? Thanks , William
