Okiebob's avatar
Okiebob
Trying to change WIFI channel
Netgear says that my security questions are invalid but they are correct so I can no longer access my router from my PC. I will be forced to do a factory reset. In order to get support from them, I must pay ransom. Before I do that, I will buy a new system from another vendor.
However, I can see my system using the ORBI app. Is it possible to change my wifi channel setting from the ORBI app?
  • plemans's avatar
    It wasn't the last time I checked (its been a while) and I'm not at home to check right now.
    A factory reset isn't hard to do.
    Its a simple as pushing and holding reset for 7-15 seconds while the device is powered on.
    And then reinstalling it.
    No need to pay for a support contract .
  • Thanks. I will do this. Is it possible to change the wifi channel using the Orbi app?
    • FURRYe38's avatar
      Channels can only be changed at the RBRs web page using a web browser.
      • Okiebob's avatar
        Okiebob
        I reset the router and it asked me to enter the serial number. I did that and it still asked me the same questions. When I entered the answers it said that they were incorrect. My desktop computer is connected to one of the satellites. Do I have to reset the satellites too?
