Canucksfan250's avatar
Nov 28, 2019
Trying to connect chromecast to RBK50
So I have a RBK50 and I’m trying to connect to my chromecast. On my network it just gives me the error cannot connect to my network. I tried creating a guest network, and I managed to actually connect. But immediately after it connected. It gives me the error Google home could not communicate with the wifi between your iPhone and chromecast so the chromecast may not be connected to wifi.
I connected to my ISPs router, which is a actiontec and it has no problem connecting to the 5ghz network. There must be a setting that is causing this issue with my Orbi. Any ideas?
  • CrimpOn's avatar
    CrimpOn
    This is only a suggestion.  I have had a couple of bewildering episodes where my Orbi turns on Access Control and sets itself to Deny new devices.  I connect a device.  It gets an IP address.  It shows up on Attached Devices.  But, it cannot communicate with anything.  Not the internet.  Not local devices.  I have to go into the Orbi web interface, turn off Access Control.  "Allow" that MAC address. Pain in the a**.
    Since my WiFi password is absurdly complex, I chose not to activate Access Control, so I never think to look there and am really surprised to find it activated.  My suspicion is that this is somehow connected to using the Orbi "app" on occasion.
    This may have nothing to do with your situation, and my suspicion may be entirely unfounded.  It can't hurt to look at Access Control.
  • FURRYe38's avatar
    What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here? If so,
    This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    • Canucksfan250's avatar
      Canucksfan250
      It’s an actiontec t3000m or something, my isp did something on their end and reset their routers option which turned off the bridged mode and then I was double NAT, do you think that could be the issue? Do you know if there’s a way to access my routers admin page if I don’t have an Ethernet connection? New laptops don’t seem to have Ethernet ports:(
      • FURRYe38's avatar
        Yes, if they disabled brige mode on the modem, this would be one cause of your problems. Needs to be in bridge mode if at all possible. The RBR is already a router which doesn't need another one in front of it.
