Charleyo
Jul 03, 2019Aspirant
TV Streaming with FIOS
I have the rbk20 with one satellite. My Home is ~2000 sq ft. Router is on first floor and satellite is on 2nd floor. My question is why can I stream tv using my fios router but when I use orbi it fails to stream tv. This doesn't make sense to me because I purchased the product to enhance my home network. I've looked at settings and my backhaul shows as poor. Is my only option to move the satellite or purchase an additional satellite to place in between my current config. Thanks for any help
What is the Mfr and model# of the ISP modem the NG router is connected too?Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option #2 or #3.
- CharleyoAspirant
Thanks for the help. I used #3 and it seemed to work last night. However my satellite shows amber so I need to either move it closer to the router or get one more satellite.
With the Orbi in AP mode you do not need to disable the wifi. Just be careful about what devices connect to.
Without more information about your network, it is hard to interpret what is going on there.
Have you tried using the satellite as it is?
The lights may be useful to see what is going on, but the real measure of things is to actually use the network and see what happens.
Probably because your Orbi router is sitting behind a second router.
Two routers on your network can cause headaches. For example, as well as the problem you see, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
If you insist on using the fios router as a wifi source, then your best bet would be to put your Orbi into access point mode. A lot of people do that without any harm to their networks.There is support for the Orbi WiFi System, including a manual, somewhere at the end of this link:
>>>> Orbi RBK50 | WiFi System | NETGEAR Support <<<<
See the section Use the Router as a WiFi Access Point.
