Retired_Member
Mar 25, 2018Unable to access internet after connecting to VPN
So I occasionally work from home and connect to my company's VPN and then remote in to my work PC. When I'm on my home network, I can successfully connect to the VPN but then I am unable to access the internet, nor able to connect to my desktop. If I create a hotspot with my phone everything works perfectly. I've tried changing a few related settings and forwarded some ports but nothing has worked yet.
- Retired_MemberJul 14, 2018
I finally figured out what the problem was. On my chromebook I had the "Prefer this network" setting enabled for my Orbi's wifi network. Once I disabled that option, everything started working fine. :smileymad:
- st_shawMaster
We need more information.
1. Are you at home on your Orbi network and connecting to your company's VPN when you have the issue?
2. What desktop are you unable to connect to--your work desktop, or your desktop at home?
3. How are you connecting to your work VPN (e.g. third party VPN client software or Windows built-in client) and what device are you using to connect?
4. What exactly do you mean when you say everything works perfectly with your phone as a hotspot? What works--connecting to the company VPN, reaching the Internet, or what?
- Retired_Member
1. Correct, I am at home on my Orbi network and connecting to my company's VPN when I have the issue.
2. I am unable to connect to my desktop at work.
3. I am connecting to my company's VPN with my Chromebook using the Cisco AnyConnect app from the Chrome Web Store.
4. Using my mobile hotspot I am able to connect to the VPN, succesfully browse the internet and my company's intranet, and am able to connect to my work desktop using an RDP client on my Chromebook.
- st_shawMaster
Thanks.
Sounds like it could be an issue with DNS.
When you connect to the VPN with the hotspot are you still using the exact same Chromebook and AnyConnect App as with Orbi?
To check whether it's a DNS issue, you can write down the IP address of your desktop at work. Then when you come home, try to connect to your desktop using the IP address. You can also try pinging 8.8.8.8 from the Chromebook once you connect to the VPN (assuming you have an app that supports ping.) If you can ping, then it's a DNS issue.
- guzzijasonApprentice
Is the Orbi connected to a router or a bridge? And is the Orbi in router or bridge (AP) mode itself?
- Retired_Member
The Orbi is in router mode, and is connected to my cable modem.
