Rustyrankin2213
Dec 23, 2021Guide
Very slow Wi-Fi after update today
Hi guys got a rbr750 with 4 sats. Was getting 600-700mb over Wi-Fi very happy, today I’ve updated the firmware now I’m getting 30-40 if I’m lucky
Any ideas
Any ideas
- It’s seems to have sorted its self out I switched everything of and back on
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you - plemansGuru - Experienced User
are you testing over 2.4ghz or 5ghz?
Maybe the new update has your device on the 2.4ghz now.
2.4ghz is much slower and sensitive to interference
hi plemans
how would i check?
Look on the device you're testing on. Some will tell you.
Or you can look in the orbi attached devices page. I think that tells you as well.
Please give feed back as well:
- econgolfGuide
I'm dealing with the same exact issue with the CAX-80. Used to get 400MBPS, now getting 30-60 after the udpate. Wondering if it's the same root cause?
Please make a new post and we'll try and help you out. The RBK7 series differs from the CAX80.
Thank you.
