RichardCP's avatar
RichardCP
Follower
Sep 10, 2017
Virgin Media Hub3 and Orbi
I live in quite a large (5 bed - 4 storey) Victorian house and currently have a Virgin Hub3 on the ground floor and one Netgear WN3000RP extender in an upstairs room.  This is not sufficient for adequately connecting all the WiFi devices we use, which includes two V6 Tivo boxes and one older Tivo (1Gb).  Can I use the ethernet spur connection into my desktop on the first floor to plug into an Orbi router and then reconnect the desktop using a cable from the Orbi into the desktop tower to create an additional network on this floor, perhaps with a satellite a couple of rooms away to power a second desktop via ethernet cable, without turning off the Virgin Hub 3 which networks the 3 Tivo boxes via WiFi?
  • StephenB's avatar
    You can use Orbi as an AP (access point) with your existing Virgin Media Hub3.  You could leave the Tivos connected to the media hub, or you could turn the hub3 wifi off, and just use Orbi.
    Another option is that you could double-route (using the Orbi as a router behind the Virgin Media Hub3).  That would let you use the routing features of the Orbi (for instance it's OpenVPN support).  If you do that, it would be best to turn off the hub3 wifi.
    • MarkSewell's avatar
      MarkSewell
      Guide
      I have the SH3 in modem mode and use the Orbi for everything, bar the satelitte issue (which is a bug, not related to this) it's worked well for me.
      • Bing-Stroller's avatar
        Bing-Stroller
        Luminary
        Same here with the SH3 in modem mode.
        As a modem it is rock solid - but I wouldn't use it for anything else.
        Also helps that I am in a non congested area so my 200Mb normally speedchecks at 210Mb and I've only lost connection once in the last year :smileyhappy: (touch wood)
    • JYG83's avatar
      JYG83
      Hello
      If I keep the Virgin Hub3 in router mode and disable all WiFi, should the Orbi Router be in router mode or be set up as an access point?
      In essence, what are the differences between:
      (i) Virgin hub3 router + Orbi as an AP; and
      (ii) Orbi as a router behind the Virgin Media Hub3 as a router.
      (in both instances turning off the hub3 WiFi)?
      Thank you
      • FURRYe38's avatar
        Recommended configuration if you want to use the Orbi router as you main host router, bridge the ISP modem fully so it passes the public IP address to the Orbi router. This helps elliminate a double NAT condition.
        If this can't be done with the ISP modem, then use the modems DMZ feature for the IP address that the Orbi router gets from the ISP modem. Disabling all wifi radios on the modem.
        Or use the ISP modem as your main host router, disable all wifi radios on the modem and use the Orbi system in AP mode, connected LAN to LAN. Not WAN to LAN.
        JYG83 wrote:
        Hello
        Thank you
  • FURRYe38's avatar
    Glad it seems to be working better. Hoping next FW update will stablized it even more.
    Yes, theres been issues with using SONOS devices. They seem to cause problems here and there.
    You could try this, Enable the wifi on the HUB and set the channels on 2.4Ghz to far away from the Orbi, So if you set channel 11 on the Orbi, use channel 1 on the modem and connect the SONOS devices to the Modems wifi. You can always drop back and disable if something happens.
    Ya, theres issues with Intel based modems:
    http://www.badmodems.com
    • koregan123's avatar
      koregan123
      Tutor
      Oh brother here we go again!! - after about 2 days of decent wifi its started to fall apart again
      i have setup my virgin media hub 3.0 in modem mode, disbled wifi, put the orbi’s ip address in the DMZ, downgraded the orbi firmware back to 2.0.1.4 manually, moved the sattelite within 25 feet with not even a wall inbetween, manually separated the orbi and sonos channels and the system drops regularly whether the sonos is switched on or not (worse when it is switched on)
      my sattelite seems to drop probably once an hour when sonos is not on and connected to more often when it is. The wifi drops and i have to reboot some of the connected devices even when it comes back up to be able to reconnect (android phone and ipad)
      I have read virtually everything i can on orbi, virgin and sonos forums and am a tad frustrated
      my house is not that large (i live in london so our houses are pretty small) it has quite thick walls and my orbi and sonos boost base devices have to be in the kitchen where the broadband enters.
      i have tried the system with no sonos plugged in and the sattelite still drops regularly as ive said
      i know technology as i have a first class honours degree in software engineering, ive read posts on these forums saying ‘wifi is just like that’ or ‘be patient’ but i’m really not at all happy with netgear right  now. This is supposed to ne a consumer configable wifi system. I can get a decent router for £50 but i chose to buy an over spec system so i got good wifi everywhere in my home for over £300 - it worked fine for probably 9 monhs then recently seems to have fallen apart and noone seems to have any idea why.
      i would buy another system but im still hopeful that netgear will fix these issues or at least tell us what limitations there are in use. Noone told me that i could not use sonos, android devices, ios devices, hiuse my orbi next to a fridge etc. when i bought this system - is it really THAT sensitive?
      is there any sign of a new firmware fix, something to give me faith anyone cares or is even working on this or do i just throw it away and attempt to start again with a different system?
      i have powered everything down and switched it all on stage by stage leaving 10 minutes between for everything to stablise but to no avail.
      if anyone can spot a basic ‘have you tried this’ that im missing please shout as im at.a loss as to what to try now  - thanks guys
  • FURRYe38's avatar
    #2 "If this can't be done with the ISP modem, then use the modems DMZ feature for the IP address that the Orbi router gets from the ISP modem. Disabling all wifi radios on the modem."
    => that's beyond my competencies! should I make the changes in the ISP modem (Virgin) or in the Orbi? could you please explain step by step what IP address should I copy and where?
    You'll make changes on the ISP modem/router. There should be a DMZ option here. If you need more help you can ask your ISP to help you configure this for the Orbi Router. If you find the DMZ, input the IP address the Orbi router gets on it's WAN port, into the DMZ. You might set up a IP address reservation for this same IP address as well ON the ISP modem so it doesn't change and cause problems down the road.
    => does it mean a lower network security? NO, since the Orbi router has a firewall too. Your safe to use the DMZ on the ISP modem.
    => would you recommend #3 over #2? I prefer #2.
    #3 "Or use the ISP modem as your main host router, disable all wifi radios on the modem and use the Orbi system in AP mode, connected LAN to LAN. Not WAN to LAN."
    => in that case I connect via ethernet from the ISP modem LAN port to one of the Orbi LAN port (not the yellow one)? YES
    Your interferences coming from the adjacent area maybe a problem as well. You'll need to scan for any wifi and channels being used there and adjust the orbi for manual channels accordingly.
    If your going to use an Orbi Satellite and Orbi router, you can place the router near the ISP modem or a bit more centrally then place the satellite at the opposite end near the bed room. Should be about 30 feet minimum in between.
    JYG83 wrote:
    Hello
    Thank you
    • DB2k's avatar
      DB2k
      Did this all get resolved? My new Orbi RBK50 and my virgin superhub 3 are not friends.
      Sometimes it's stable for hours then it is just unusable for hours on end as the internet connection drops from the virgin hub and then it keeps trying to restablish connctivity. I talked to Virgin and the engineer things its the Orbi doing something. I have no idea how the Orbi can be making the Virgin hub drop it's internet connection - anyone else seen that?
      My SH3 is set in modem mode with wifi disabled (red light on the front of the box).
      I haven't done anything specific to the Orbi but I'm now wondering if I need to change the DMZ settings perhaps?
      Frustrating!
      • Hi Db2k
        ’Resolved’ is a strong word. I found the best setup for me was to setup the SH3 in Router mode (note not modem),  disable the wifi and add the Orbi IP address to the SH3 dmz. I still had some issues however moving the Orbi satellite around seemed to solve that over time (my devices seemed to mess around reconnecting to either the satellite or main router a lot). I found that the satellite can be ‘too close’ as well as ‘too far away’ which makes the whole setup seem a little flaky if you want my honest opinion.
        i also downgraded the firmware on both router and satellite to an older much more stable version as the newer versions of firmware seemed to introduce a ton more issues (there are plenty of posts on here outlining the last ‘stable’ firmware upgrade for your specific model - hopefully this has been resolved recently)
        i have since taken the plunge to have my entire house hard wired with cat6 as i was frustrated with crappy coverage and dropped commections so i will likely be posting questions on here soon about using a hard wired backhaul in my setup once the system is put in.
        good luck - many of my friends told me that £350 for a wifi router in a medium sized 3 bed semi was overkill but i still havent cracked reliable and stable wifi - one day maybe
        for me this system is over complicated and netgear should really focus on the basics of coverage, dropped connections and speed. They seem more interested in introducing new features like daisychaining instead of solving the ‘satellite is too close’ kind of basic flakiness.
        Hope this helps
