PWBerry
Feb 09, 2019Guide
Voice over Wifi
Cell service in my area is bad, so I use voice over WiFi on my iPhone. My internet service max speed is only 12 MBS, very slow. Once I switched to using the RBK50 mesh router, about 50% of the times the person on the other end of the phone says my voice is choppy. This did not happen with my
previous router. Is there a setting that will give my
iPhone connection more bandwidth to stop the choppy voice?
- Chuck_MMentor
A couple of questions for you:
What is the speed test reporting for you?
Under advanced setup | wireless settings
Can you tell us what those are set to right now? (What boxes are checked and not checked?)
Finally, what version of firmware are you using>?
- PWBerryGuide
Answer to your questions:
What is the speed test reporting for you? very slow.. Download = 6.78 mbps Upload = 1.46 mbps
Bold items are checked under these sections:
Advanced Wireless Settings (2.4GHz b/g/n)
Enable SSID Broadcast
Enable 20/40 MHz Coexistence
Enable WMM (Wi-Fi multimedia) settings
Advanced Wireless Settings (5GHz 802.11a/n/ac)
Enable SSID BroadcastEnable WMM (Wi-Fi multimedia) settingsBackhaul Topology
Enable Daisy-Chain TopologyFinally, what version of firmware are you using>? V2.2.1.210
- Chuck_MMentor
Regarding daisy chain, are your satellites in serial or parallel (e.g. are they in a line or in a hub and spoke from router)
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?What phone are you using when making these calls?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using? Try WPA2 and AES only.Try enableding Beamforming and MIMO.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Disney Circle: https://community.netgear.com/t5/Orbi/WARNING-Firmware-2-2-1-210-is-junk/m-p/1667485/highlight/true#M45926
iPhone connection more bandwidth to stop the choppy voice?- PWBerryGuide
Answers to your question:
What FW is currently loaded? V2.2.1.210
What is the Mfr and model# of the ISP modem the NG router is connected too? AT&T Arris NVG589
Is the Orbi system operating in Router or AP mode? RouterWhat phone are you using when making these calls? iPhone 6 and iPhone 7+
What is the size of your home? Sq Ft? 4000
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials. around 50 feetWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz. 2.4HGz = Auto and 5GHz = 48
Any Wifi Neighbors near by? If so, how many? No
What WPA security modes are you using? Try WPA2 and AES only. Using WPA2-PSK [AES]- FURRYe38Guru - Experienced User
Your ISP modem already has a built in router and wifi. This will cause problems with the Orbi and devices connected to the orbi and cause a double NAT condition which can also cause other problems.
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Just to add to this:
I'm experiencing the exact same issue as described by OP, but on a reasonably fast Internet connection (80-90 Mbit down, 30-40 Mbit up).
Voice over WiFi works well in one direction, I can hear the other party perfectly, crytal clear and without any kind of issue. But absolutely everyone complains about the fact that my voice sounds distorted and garbled. Not immediately, but after 30-90 seconds of phone call.
And, yes, just like op, the issue only started with Orbi - there were no such issues on the previous, non-mesh router.
So I don't think Internet connection speed is the issue here.
I toggled all settings mentioned here already with no avail. It's also a rather annoying issue to troubleshoot since it requires a partner to call and annoy with a garbled voice.
- ekhalilMaster
What ISP mode/router are you using? Does it have any routing capability?
In order for Orbi to provide you with optimal routing fuctionality, there should not be any other box in front that manipulates the routing.
- PWBerryGuide
The ISP router/modem is an AT&T Arris NVG589. It was my main wireless router until I purchased the Orbi. Then I turned off the wifi setting in the ISP router since I was now using the Orbi wifi. I still need the ISP router to connect to AT&T.
