Dec 20, 2019Guru - Experienced User
Voxels FW available for 50 series Orbi only available.
Any one interested or users with Orbi that have units outside of there warranty period, can give Voxels FW for Orbi 50 series systems only, a try:
This is based off the new v2.5.1.8 stock NG FW.
Post your experiences or any problems you might see regarding Voxels FW here:
https://www.snbforums.com/forums/netgear-ac-wireless.53/
Enjoy. ![]()
New version of Voxel custom firmware build: v9.2.5.2.6SF-HW
Changes (vs 9.2.5.2.5.1SF-HW):
1. Toolchain: Go is upgraded 1.14.7->1.15.3.
2. Toolchain: binutils version is upgraded 2.35->2.35.1.
3. Toolchain: -finline-functions compiler option is added to GCC.
4. Kernel level acceleration (-O2, -march=armv7-a -> -mcpu=cortex-a7, -finline-functions, etc.).
5. wireguard package is upgraded 1.0.20200729->1.0.20200908.
6. Change kernel config and OpenSSL 1.1.1 to allow using dynamic devcrypto and afalg engines (HW version).
7. OpenSSL v. 1.1.1 package is upgraded 1.1.1g->1.1.1h.
8. OpenSSL v. 1.0.2 package: change default config directory.
9. Fix Smart Lock icon issue (WebGUI).
10. jansson package is upgraded 2.12->2.13.1.
11. libjson-c package is upgraded 0.14->0.15.
12. expat package is upgraded 2.2.9->2.2.10.
13. nano package is upgraded 5.2->5.3.
14. Change SAMBA config generation (for Android/iOS gadgets, issue reported by Rustypouch).
15. Make an order in samba36 Makefile.
16. logrotate package is upgrader 3.15.0->3.16.0.
17. cifs-utils package is upgraded 6.10->6.11.
18. iperf3 package is upgraded 3.8.1->3.9.
19. Fix proftpd issue: display size of large file (thanks to R. Gerrits).
P.S. My README.1st and QuickStart.txt:
(!) IMPORTANT NOTE: it is strongly advised to update to the stock firmware 2.5.2.4 before flashing this version. If your on a older stock version than v2.5.2.4, then you'll need to update to stock v2.5.2.4 first before you apply v9.2.5.2.6SF-HW.If you are already using Voxel FW and up to date, then this "update to the stock firmware 2.5.2.4" is not needed of course.
The link is:
https://www.voxel-firmware.com- FURRYe38Guru - Experienced User
New version of my custom firmware build: 9.2.5.2.14SF-HW.
Changes:
1. Toolchain: binutils version is upgraded 2.36.1->2.37.
2. Toolchain: Go is upgraded 1.16.5->1.16.6.
3. QCA drivers/firmware are upgraded (integration from V2.7.3.22 stock).
4. wireguard-tools: add PresharedKey support to WireGuard client.
5. OpenVPN is upgraded 2.5.2->2.5.3.
6. curl package is upgraded 7.77.0->7.78.0.
7. proftpd package is upgraded 1.3.7a->1.3.7b.
8. gettext-full package is upgraded 0.19.8.1->0.21.
9. ethtool package is upgraded 5.12->5.13.
10. ipset package is upgraded 7.11->7.14.
11. e2fsprogs package is upgraded 1.46.2->1.46.3.
12. util-linux package is upgraded 2.37->2.37.1.
13. Change WebGUI logo.
14 Kernel: Use FSCACHE as a kernel module.
15. Host tools (e2fsprogs): is upgraded to 1.46.3.
The link is:
https://www.voxel-firmware.com- CrimpOnGuru - Experienced User
Installed fine for me. LIke his Logo on the home page.
Does moving to Voxel's firmware give any more info for bandwidth utilization? The stock Orbi stuff tells me the aggregate of usage, but not per device.
I am interested in per device usage, so I wonder if Voxel provides that.
Something to ask Voxel about over in the SNB forums.
I don't believe his FW does though...
standarduser73 wrote:Does moving to Voxel's firmware give any more info for bandwidth utilization? The stock Orbi stuff tells me the aggregate of usage, but not per device.
New FW available from Voxel for Orbi 50 series users if interested: v9.2.5.1.11SF-HW
http://www.voxel-firmware.com/Downloads/Voxel/html/orbi.html
New FW available from Voxel for Orbi 50 series users if interested: v9.2.5.1.12SF-HW
Oh, my. OpenVPN Client. There was a post just yesterday asking how to get one. What timing!
- SW_Prodigy
(a) To set a separate SSID for the 5 GHz network on your Orbi RBR:
• From telnet/ssh console run
Code: nvram set wla_ssid="NAME OF YOUR 5GHZ NETWORK" nvram set allow_diff_ssid=1 nvram commit
• Reboot your RBR and RBS
• Set “allow_diff_ssid” in nvram to “0” to disable separate SSIDs.
NOTE:
It is not recommended to separate the SSIDs.
Your connection could be unstable.
Under your own risk.Nice addition, but still risky to enable it seems.
