TheBigGameHuntr's avatar
May 13, 2020
Why Am I Not Getting the Speed
My admin app shows I am getting the more than 400mbs I am paying for but my computer speed tests are showing 1/4 on one computer and 1/8 on another.
What can I do to get my speed up?
  • FURRYe38's avatar
    Is your PCs wired or wireless?
    • TheBigGameHuntr's avatar
      TheBigGameHuntr
      I am running current firmware 2.3.5.32
      HITRON E31N2V1
      Windows 10
      Cable is set up for 400 speed (I'm getting half that)
      My computer is set up for wireless
      Orbi admin tells me I should get more than 400. I'm getting low 200's
      • FURRYe38's avatar
        What are your wired results with the PC?
        What is the mfr and model# of the wireless adapter in this PC?
        https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
