Mkstretch's avatar
Mkstretch
WiFi dropping
I had a blackout the other day and since then my work VPN is losing connection periodically, and my security system daily test is showing abnormal WiFi tests. Is their a way to test for issues? Or does anyone know what could be going on.
  • FURRYe38's avatar
    Find free wifi analyzing apps on apple or android pads to see what kind of nieghboring signals are around you.
    https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
    Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
  • I guess it’s possible that after your power outage, your system came back up with default settings instead of a custom setting or settings you had in place.  You might go through and double check your configuration.
  • Thanks guys I'll check this all out. Also I'm using my orbi in AP mode with my Verizon quantum gateway router if that matters.  I'm running the latest firmware. I'm on auto channels.
    • FURRYe38's avatar
      Be sure any wifi on the verizon gateway is disabled fully as well.
      Let us know about the other suggestions.
      • Mkstretch's avatar
        Mkstretch
        Ok. Also my house is 3900sq ft.  Is it better if I hard wired one of my satellite?
