neosunny
May 01, 2018Tutor
WiFi printer problem
I have a wifi printer (Canon PIXMA TS6070) which was function very well in my previous wifi network.
Recently, I have established a new wifi network using the Orbi RBK40 and the previous one was di...
- May 02, 2018
neosunny wrote:
Could anyone give me some advices to solve the problem please? I am so frustrated...
Did you see my post on the previously linked thread?
I had the same problem when first settting up and again after a factory reset. It was fixed by setting the 2.4GHz channel to ‘11’ rather than ‘auto’ in the Orbi admin pages ("Advanced, 'Setup', Wireless setup').
My printer (Canon MX-870) couldn’t see channel 13 which the auto setting had used to deconflict from neighbor’s signals.
neosunny
May 11, 2018Tutor
Recently, I have established a new wifi network using the Orbi RBK40 and the previous one was discarded. The performance of the Orbi wifi network is working very good and performance is very good too. All my mobile devices (such as notebook, iPad, mobile phones) can join the new wifi network easily with connecting to the new SSID created. However, my wifi printer is failed to join the wifi network. At the panel screen of the wifi printer, it cannnot detect the SSID of the Orbi network but it can detect all other SSID of my neighbour's network. I don't understand what the problem is. Right now I cannot use the wifi printer wirelessly.
Does anyone here knows what the problem is and have solution for this problem? Please give me some advice. Thank you very much.
Finally I am free from busy and try to tackle the problem again. And the problem has been solved.
I have a discussion with Canon technical support. The technician that I spoke with said that all Canon wifi printers can only support 2.4GHz and channels must be 1 to 11. He said the problem should be router using a channel out of the range of Canon printer. So, I check with the Orbi system. The Orbi system is using channels 1 to 13 and has set as "auto" by default. It Orbi use channel 12 or 13, then the printer will not communicate with the Orbi system. And finally the printer can not detect the SSID of Orbi system.
So, I manually changed the Orbi 2.4GHz channel from "auto" to either one of between 1 to 11 that the printer can support. I set it as channel 6 by random. After that, the wifi printer can see / detect the SSID of the Orbi system. And the problem has solved! Thanks god!
I would like to thanks user Ulairi who has provided me the right hints to tackle with this problem.
- FURRYe38May 12, 2018Guru - Experienced User
Glad you got it working. Enjoy. :smileywink:
