jackiep
Sep 11, 2016Follower
Will Orbi Satellite work with existing Netgear Nighthawk X8 router?
I recently purchased a Nighthawk X8 router, so I don't need an extra router. My X8 is placed in the center room of our house. Our home built in 1926, is 3,000sq' it has older plaster walls & the wi-f...
farfromovin
Jan 20, 2017Guide
What is stopping you from naming your access points the same SSID? I hard wired 2 routers as access points to my main router (all Asus units) with the same SSID and it worked fine. Your device that is traveling will eventually connect to the strongest one.
