JW_Wimpy
Apr 13, 2017Guide
...another LB1120 question.
Just purchased the LB1120, but haven't received it yet. I assume it doesn't include a SIM card, but does it have an IMEI number?
Tried to sign up with Cricket (owned by AT&T) online and they insist that I provide them with the IMEI. Their customer support person said to use the IMEI from any phone, but the only mobile phone I've got was provided by my employer and I'm reluctant to give them that number as I don't know how they might use this info.
The LB1120 IMEI will be printed on the label on bottom of unit.
Steve
- steveswNETGEAR Expert
Steve
- JW_WimpyGuide
- egaviriaAspirantDoes anyone know how many wireless devices can I connect to this LTE modem?
- DarrenMSr. NETGEAR Moderator
LB1120 has 1 Ethernet port on back of it so only one device can be connected directly to it however the device has two modes of operation bridge and router mode in router mode (default operation mode) you can connect a 8 port, 16 port, 24 port switch or a router which will allow you to connect lot more devices.
DarrenM
- egaviriaAspirantThanks.
Now I have another problem. After a while, device turns off celullar data by itself. It is currently set in router mode connected to an Apple Time Capsule. How can it set it up in order that the internet in never disconnected?- DarrenMSr. NETGEAR Moderator
Hello egaviria
You may want to check page 55 of the manual make sure the setting to shut off after using so much data is not on.
http://www.downloads.netgear.com/files/GDC/LB1120/LB112x_UM_EN.pdf
DarrenM
- egaviriaAspirant
Darren
I don't see that option on page 55. Shows only options for setting limits, but nothing about turning off after a particular data usage.
- JW_WimpyGuide
Anyone have a source for info on using external antennas for the LB1120?
I had picked up a MIMO paddle antenna at the same time as the modem. Tried it without, first. Only got 1 to 2 bars. The paddle antenna (after cycling the power, of course) didn't make a significant difference. I toyed with it a bit, but I admit to not having seriously tried optimizing its location as the optimal location is most likely going to be inconvenient (about a 1 meter cable from the antenna to the unit, so the unit will have to go where the antenna works best).
I use the modem only at home currently and I'm considering a yagi antenna (or two?) in the attic with quality, low-loss coax down to the modem. I look forward to finding TS-9-to-some-reasonable-connector adapters (not really).
- vronpGuide
Any luck on the antenna front? So far, the best looking antenna I've found is a Panaroma brand but it is pricey at around $150 and the gain at 700Mhz is only 2dbi.
All the stuff on Amazon seems to be garbage....
- JW_WimpyGuide
I had forgotten that people don't write things up anymore, they make videos. Turns out YouTube was a good source of info on external antennas. The paddle antenna is working adequately for now, I'll look into doing an attic mounted yagi in the fall when it isn't 130degF in my attic.
