GusRandall's avatar
GusRandall
Aircard 340u Problem with Windows 8.1
I bought a brand new Windows 8.1 Laptop and Aircard 340u. I updated Windows 8.1 fully and then plugged in Aircard in. Supposedly, when you plug it in, Windows is supposed to recognize the device and install the drivers. That did not happen. Nothing happened when I plugged in the device no matter which port I used and no matter how many times I clean booted and tried again.
I plugged the device into a second Windows 8/1 laptop that I have and it worked perfectly - it immediately installed the drivers and worked. I have no explanation as to why it won't work in the new laptop. Neither did AT&T, nor HP, nor Netgear who I spent over 4 hours on the phone with yesterday.
  • If I plug a basic USB2.0 hub into the laptop and then plug the Aircard 340u into the USB hub, the laptop can detect the modem and connect. My sense is that this may be some kind of USB port timing issue as I saw reference to a similar issue in a different forum addressing a different combination of the Aircard and another device (which I think converted the Airdcard into a HotSpot).
    While a USB hub works, it does add bulk and one more thing to carry around so I would really like to find a way to fix the problem in the USB control. Something happens in the hub that allows the computer to see the modem so surely there is a way to change some USB settings to accomplish the same thing. Maybe a way to downtune a USB3.0 port on the laptop to USB2.0?
    Any ideas?
    • Jlittle489's avatar
      Jlittle489
      Tutor
      Did you ever get this resolved?  I have exactly the same situation - New HP Elitebook Folio 1020 with a 340u.  It does not work plugged directly in, but works fine if you plug it into a USB 2.0 HUB.  It works fine on my old HP laptop without the usb hub.
    • By plugging the device into another PC and running the AT&T AllAccess Software show that the firmware is "NTG9X15C_01.13.12.13 r18963 ntgrbc-"
      • nhann's avatar
        nhann
        NETGEAR Employee Retired
        Hi Jlittle489,
        Thanks for clarifying. There is a new version 01.13.12.14 now available that was released 8/7/2015.
        Please follow the documentation to complete the upgrade.
        I hope to hear back from you.
        NhanN
