stigarius's avatar
stigarius
AirCard 790S Status data usage
Cant seem to get the counter started on the device (router). Counter works in smartphone app for session in use but will not udate days left or data usage on the router.
(PRI version: 01.06)
(Web App version: AC790S-1_03.03.103.64)
Tried to update/ check for firmware updates but get error. (Yes i am connectet to netprovider)
Any pointers here?
  • Thank you for sugestion. Actually i just got an firmware update (5 minutes ago) and now everything works as it should.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello stigarius
    I would suggest using your ISP data counter as it would be the most accurate for what you are using.
    DarrenM
    • stigarius's avatar
      stigarius
      • lochan3840's avatar
        lochan3840
        Excuse me
        I also have a similar situation in the main picture can not show the data where can I get a software update can you help me get it?
