DaCassilia06's avatar
DaCassilia06
Can't Enable Wifi on ATT M1100
Hello Guys
i Have bought two Att Nighthawk  M1100-2A1NAS from ebay , one is working perfectly fine , but the other one only works thru ethernet or with USB C tether it  always shows : Wifi Disabled
I tried to activate it in the router portal but it failed ,
I got a lot of issues in going into the portal it doesn't show up like you can see in attached files
I think this is a Software issue , someone has any clue?
Thanks
    • DaCassilia06's avatar
      DaCassilia06
      Yes I've tried but it didn't worked , and for some obscure reasons this one says that I can manage it on ac81xs.mhs/ instead of attwifimanager/
      • Nuchem's avatar
        Nuchem
        Have your issue been resolved? If yes, can you share with us how? because I'm experiencing the same issue
  • plemans's avatar
    Have you checked to make sure IP-passthrough is disabled?
      DaCassilia06
      I cant access to the portal , i think that he doesn't responds , for example when i want to reboot thru 192.168.1.1 it does absolutely nothing
    • Mi9htyMarcu5's avatar
      Mi9htyMarcu5
      Initiate
      I have a nighthawk mr1100 and I can’t get it to work, I’ve been on the phone with att and I’ve been to their stores and they all tell me to use the app but without a internet connection I can’t use the app. I have a unlocked device and I’ve tried 2 different carriers in the last 2 weeks and still can’t get it to work. It say I have to finish setting it up to visit a website but all the websites they try to send me to crash and I can’t use them it also say I have to update my apn settings and I can’t do that either, that’s what I think the problem is but either way I can’t use my product and it’s disturbing. I am now at my home and I plugged my Ethernet cord from the wall into my hotspot to try to work it that way and still nothing
  • ArodiD's avatar
    ArodiD
    NETGEAR Expert
    Hi DaCassilia06 ,
    Can you please PM a screenshot of the device label?  You will need to remove the battery to see the label.
    Arodi
