rcoble
Feb 05, 2020Tutor
Data display on AirCard 810S Mobile
i have had this device for quite awhile, and never had an issue, recently i had issues with accessing my telstra account online, and needed to change from IE to Chrome, as well as change passwords,,, around this same time i noted that the display on my device stopped showing data usage, days left etc,, and now only says "detecting service". this could be just coincidence with the first issue, but after long discussions to solve both issues, no one seems to know how to fix this..... any help would be appreciated, i know i can go on to my computer and check, but so easy to check on the device, especially when i use the modem away from home as well...thanks
Sorry for the inconvinence. We did submit the fix to Telstra a month ago for Telstra approval. But the testing was delayed in Telstra lab.
Thanks
John
- JohnPengNETGEAR Expert
Telstra updated its data usage server and caused the issue for most of the devices. An update is going through Telstra testing. Hope we can release the update in the next couple of weeks.
Thanks
- rcobleTutor
thank you JohnPeng for your reply,,, i will keep a check on it and be abit more patient,,,
- rcobleTutor
hi again,,, has there been any movement on the problem,,, my device still only showing "detecting service"..... quite annoying not seeing the information and having to log into the computer, any updates ????????
Thanks
John
