Visserd
Aug 21, 2019Aspirant
DC112A firmware update fails
I tried to update firmware on my Dc112A. It says there is a new update available. When I select to update it gets to the stage where it is updating language file and fails. I have tried resetting modem and tried several times with no success. I also tried to look for the new firmware files but i can't find them in the download centre
- LlamaLarryLuminary
Why isn't there a link to the firmware file on the Netgear site? This is surprising how poor the support is on this product.
Kind of good to see routers in other languages are having an issue. I tried switching from English->Auto->German->Spanish all with the same error.
- Tom500Aspirant
I have the same problem.
I tried to update the firmware of my Dc112A-100EUS. (old firmwar : V1.0.0.34_1.0.60 and the new : 1.0.0.44_1.0.60)
It indicates that a new update is available. When I choose to update, it comes to the stage where it updates the language file and fails. I tried to update firmware on my Dc112A. It says there is a new update available. When I select to update it gets to the stage where it is updating language file and fails. I have tried resetting modem and tried several times with no success.
I also tried to look for the new firmware files but i can't find them in the download centre.
Why is the suport for this produkt so bad?!
Model: DC112A-100EUS
- AziiizanAspirant
I have the same problem can not update my firmware hope for a reply.
- GkespyTutorI'm still having the issue. DC112A-NAS. Error loading language file. Can't update. Come on, Netgear!
- I am very disappointed with Netgear's extremely poor handling of this matter.Do you know what is wrong or not?
The fact that it will take over a month for your technicians to find a solution is not realistic and there is no real dialogue.
You have developed and sold the Smart Cradle, but you forgot the support somewhere along the way.Why is there, for example, no page where we can download these FW manually?
Visit the download center and enter "DC112A".
Firmware / Software: not available for this model.
Give us an answer now!It is now six days since the Netgear Moderator latest post...
We get no answers, so the question is whether Netgear wants the hardware in return?The timeline with all the misleading answers from Netgear can only mean one thing - that it's hardware failure.
If there were only problems with the firmware, it would have been fixed a long time ago!
It seems to be the new standard for NetGear support, wait time is +-10 days for some nonsensical, half baked, no value, re-iterated BS response that addresses nothing and solves nothing.
i just cannot understand why they don't release the firmware to the download center so we can at least rule out a problem with delivery via the webUI. We were alerted to the security fixes in the firmware quite some time ago in a Netgear email campaign, and now they they have decided to actually push out what they said they did it doesn't even install.
I used to think Netgear's reputation was bulletproof from using their managed and smart switches, but now I'm not so sure.
- yoyojpgTutor
Oyé Oyé!
Warning!! Here, the firmware is available.
I put you the link to download.
http://www.downloads.netgear.com/files/GDC/DC112A/DC112A_V1.0.0.44_1.0.60.zip
You will need to unzip it in a folder (on the desktop for example to have it at hand)
For installation, go to "Smart Cradle"> Management / then click on the tab "ADVANCED" / then "Administration" / then "Update Router".
Then select the file "DC112A-V1.0.0.44_1.0.60.chk" and OK
The router will restart. Internet will cut itself.
The key will restart.
If no change and the firmware number remains unchanged, try again.
The key may alert you (1). Do not panic, go to settings and reset. She will ask you again, click on it and leave it to connect.
Restart your PC to fix everything here and there!
It took a while but we got there.
Thank you all for your perseverance. It has to pay!
Good continuation.
Yohann
Hi. I have tried these steps and all I get is that the file is incorrect
Thanks
- wwglenAspirantDC112A-2RDMES
Automatically updated the language file to:
V1.0.0.42_2.1.38.3
But will not automatically or manually update firmware:
V1.0.0.18_1.0.60
Thanks Now I've had enough of Netgear's abusive support.
We will replace all equipment related to Netgear and change to another brand that cares about its customers.
