PMcV
Sep 23, 2024Tutor
Error Type #2 Reason #211
My Nighthawk MR6550 keeps dropping offline with the screen showing "Error Type #2 Reason #211". Netgear tech support has not been able to tell me what this means. What does it mean? Can I fix this or is it something netgear has to fix? Many thanks in advance.
- Blanca_ONETGEAR Employee Retired
Hi PMcV,
Please send me a private message with your support case number.
Blanca
Community Team- templates2AspirantHello good evening, I want to know how you managed to solve the error type 2 reason 211 I have the same device and it gives me that error, the device is unlocked and I want to put a postpaid nano verizon card in it, I have already updated the device to the firmware NTGX65_12.01.54.00
- PMcVTutor
I never solved it, sorry. I bought one MR6550, had that problem, tech support never told me what the error meant or solved the problem, returned the device, second device had the same problem, returned it for a full refund. I also had a Verizon nano SIM, which I swapped out for another Verizon nano SIM to no avail. Was also using a Netgear MIMO antenna and confirmed the firmware was up to date. Wasted hours of my time in the process. Not sure what Netgear's problem is but both MR6550s were duds, and tech support asked a lot of questions but gave me no answers. Sorry I couldn't help you. The MR6550 is a great concept but a worthless device, and no honesty from tech support.
- williamBoothAspirant
This device was functioning as expected with firmware 12.01.47. I just upgrade to 12.01.54 it no longer will connect. From reading the forums, it appears as though people think it's a Verizon issue. I believe it's a Netgear issue. I should probably return the device since I doubt Netgear will have this resolved anytime soon.
The service is now working. I have a static IP and the APN was set incorrectly after the firmware update. Now that the correct APN has been entered, all it good.
- jkwizz67Aspirant
I am having so much trouble with mine! Just like yours it was fine before the firmware update and now with the 12.01.54 it is giving me the error. How do I fix the APN?
- SparkSlashAspirant
Just to inform any who come here for answers, both Error - type #2, reasons #209 and 211 are network authentication errors. This means that they are unable to aquire enough local bandwidth and network speed to authenticate with the cellular provider. Verizon definitely has capacity problems in most areas, resulting in speeds that drop to less than 1Mbps, which is well less than what is needed to keep the device authenticated and provide data traffic flow.
