salvagetec
Feb 24, 2018Aspirant
LB1120 SLOW SPEED WITH ATT SIM
This is my 3rd LB1120 modem. I first install was 2 at work off a Sonicwall, for fail over connection. They had slow download speed at first of 5mbps down. Yet my cell phone was getting 28mbps down in the same spot. Both on ATT, but different bills. ATT try saying modem couldn't reach the 4G lte tower. And I was in a 3G area and that was the best they could do.
So they did get fixed by a installer of wireless modems. Something on the ATT side.
Well my 3rd LB1120 is for me. And max download is .5-3mbps. And now my phone is getting about the same speeds. Its like add the Netgear LB1120 trigger something in my ATT account that slowed my data plan down. I was getting 16 to 30mbps at home before the new sim card was turn on. Anyone ever have this happen? I'm on the 2nd week of phone tag with ATT support. 5 new sim cards between my phone and modem.
- JasonNNETGEAR Employee Retired
Hi salvagetec,
Sorry for your inconvenience. I was wondering if your LB1120 device was up to date with it's firmware. Also the NETGEAR LB1120 cannot change anything to your AT&T account.
- Jason N
- salvagetecAspirant
Yes I update the driver first thing.
Hi salvagetec,
I just wanted to check in with you and see if your issue has been fixed.
- Jason N
Saturday night I called ATT tech support try to find a fix to the slow data speeds. The tech inform me, my house is was only 1/2 mile from a 3g tower. With a $100 outdoor mimo antenna I get 3 to 4 bars. Kind of odd I'm not getting better. The modem page shows 4g connection. My best speed was 10AM Sunday mornig. 8 mbps down 13 mbps up. Do able speed for most. But most of time time its .5-3 mbps down and 5-7 mbps up.
Is it normal to see faster outloads?
My fear is with all the new ATT plans with speed caps. I got added to one when the modem was added.
