mgandalf's avatar
Oct 29, 2017
LB2120 and Ubiquiti EdgeMax - LAN resetting
I have an LB2120 running the latest firmware connected to a Ubiquiti EdgeMax router running also the latest (1.9.7). When I place the LB2120 in bridge mode, the EdgeMax gets an IP and sets the default route then the LB2120's power LED briefly turns amber, then the LAN connection goes down. After a few seconds the LAN comes back up only to restart the cycle a few seconds later.
If I place the LB2120 in router mode and connect the EdgeMax, the LB2120 stays connected for a longer time, but after about 30 seconds the LAN connection goes down and the power LED shows a solid amber with the first two bar LEDs lit still showing the last signal. When I reconnect the LB2120 to a computer or access point, the LAN connection stays down and the power LED stays amber until I reset the LB2120.
When running EdgeMax firmware 1.7.1, I did not see this behavior, but I was forced to upgrade due to the /32 and default route issue.
- Mark.
    • JamesGL's avatar
      JamesGL
      NETGEAR Employee Retired
      Hi mgandalf,
      You have mentioned that issue did not occur when you have downgraded to previous firmware of your EdgeMax and it only happens with the latest firmware. Have you checked with Ubiquiti if there is a known issue with the latest firmware?
      • mgandalf's avatar
        mgandalf
        Tutor
        Yes, I have the question out to them as well.
        - Mark.
