superjet's avatar
Jul 27, 2017
LB2120 really flaky connection, can output to syslog or no?
lb2120 running in bridge mode with AT&T service. Every so often (seems random) my router will report the connection to be down, then 2 minutes or so later it comes back up.  I would like to be able to troubleshoot by outputting the log of the modem to a syslog server. Is this possible? Are there any known issues with this model and being randomly disconnected? I saw another thread about it with no real resolution but not much information elsewhere. I'm bridging it to a AC68U modem that fails over to another connection when the AT&T goes down.
  • Were you able to troubleshoot your flaky connection? I was seeing the same issue. The only time that I haven't seen dropping and reconnecting is when I:
    1. Put the LB2120 in bridged mode
    2. Connect the LB2120 WAN port to a router LAN port
    3. Connect the LB2120 LAN port to a device (in my case a SmartThings hub)
    It's not my ideal solution, but, for now, it works as a cellular backup to just my SmartThings hub. I would rather the LB2120 be a redundant connection for my entire network, but with it dropping, it makes the router/network unstable.
    Hopefully someone has found a solution and will respond.
    • superjet's avatar
      superjet
      Star
      I just put it in router mode and gave up on getting a good vpn connection.
  • Retired_Member's avatar
    Retired_Member
    I have the same problem. I think the connection of the provider goes sometimes down for 3 seconds and the LB2120 switches to cellular.
    There should be an option to tell the device how long to wait before making the failover. Otherwise I get several message per day per downtime from the provider.
    Is there a place where we can suggest new functions?
