Sixtsixmike's avatar
Sixtsixmike
M1 antenna setup
Hello all,
Just ordered 2 Wilson 10dbi yagi's and cables and patch cords, etc.
My question is how do you have yours mounted?
Stacked, side by side, or + 45 -45
In in a rural area in east T.N. and only get 1 sometimes 2 bars @ 2-4 gb if I stand in the right spot.
Trying to limit my trips up on the roof if I can get the rig setup before and and just put some lag bolts in my pocket and a wrench and 1 and done this joker the first time! Thanks
*Sorry for the cross post in the Wi-Fi forum
  • "Stacked, side by side, or + 45 -45"
    I've been looking for the answer since last year.  I am rural as well and have a single yagi.  The answer will ultimately depend on how the Nighthawk works internally and how your local AT&T cell tower is configured.
    MIMO vs CA.  MIMO helps in city environments where radio is bouncing off of everything (buildings, buses, etc.)  In a rural setting we do not have these city multipath problems.  That said *if* the Nighthawk supports MIMO with a second external antenna, that second antenna may do nothing for you.  I would recommend you start with one external antenna to see what you get before adding a second antenna.
    CA is another thing all together.  The ability for multiple radios to work independent of one another.  *If* the Nighthawk supports CA with two external antennas the second antenna may do alot for your performance.
    Netgear does not disclose any information about how the Nighthawk MIMO or CA works.  From previous forum posts this MIMO and CA information is not exposed in Nighthawk web console so even if something is happening under the covers we will not know about it.  The only thing we'll know for certain is speedtest results!  My yagi is mounted with the elements vertical.  I have never tried it in any other orientation.  I get 50Mbit download peak speeds.
    My best advice for you:
    1) Get one antenna working the best you can to baseline performance.
    2) After adding a second antenna, try both vertical and +/- 45 setups to see what works.  I've read about +/- 45 but have NEVER seen actual speedtest results in the United States on AT&T using the +/- 45 setup.
    3) Keep the antennas at least an antenna width apart.  If your yagi is six inches wide,  mount the two yagis at least six inches apart.  Stacked or side by side should not matter at all.
  • JasonN's avatar
    JasonN
    NETGEAR Employee Retired
    Hi Sixtsixmike,
    Thanks for the question! Please try nhantenna's steps for antenna setup.
    Please let us know if those steps work for you. :]
    Also thank you nhantenna for the help. :]
    - Jason N
    • Sixtsixmike's avatar
      Sixtsixmike
      Most def, will post an update as soon as I get the gear.
      Good thing with the nighthawk is I can take everything up with me and dial it in on the roof. (It's just steep as heck) may be sketchy until I get to the peek....lol
      • JasonN's avatar
        JasonN
        Great! but always make sure you are safe please. :]
        Please let us know. Thanks again!
        - Jason N
