d4bbott
May 01, 2024Aspirant
M6 not connecting to 5G
MR6110-1A1NAS. HW Version 1.0 FW Version NTGX65_10.01.22.01
All cellular devices in my household recognize the 5G cellular network. My Nighthawk M6 will not allow the 5G settings for the APN. It acts like there are too many characters. The 5G APN is ATT NR Broadband, it will stop at Broadban. I've tried no spaces, still no luck. I've reset, done a hard reset, removed and reinstalled SIM card. The SIM was previously in an M1 but ATT recognizes the M6 as a 5G device in my devices.
I broke down and took everything to a local AT&T store. They confirmed that I had done everything right, the device is a 5G device, and I have 5G service where I live. They also confirmed that this was not the first time they had heard of such an issue. Turned out to be a SIM card issue. They took a new SIM card, provisioned it to a 5G device in the store, installed it into the M6, and now I have 5G service with my hotspot.
- MobileGermanAspirant
My MR6110-1A1NAS_05.00.63.00 is not connecting to German 5G networks only to 4G/LTE.
SIM-card gives access to 5G Telekom networks
FW NTGX65_10.04.22.00
Any idea how I could fix the issue?
- W1lliamVirtuoso
MR6110-1A1NAS only supports n2/n5/n12/n14/n29/n30/n66/n77 while Germany carriers is on n1/n3/n28/n78, not a suitable model for the country you are staying.
Thanks for your explanation!
Which model is suitable for 5G in Europe/Germany?
Are you doing this through the app or on your browser?
I use my browser and it seems to still work as of the latest update.
To navigate in your browser on a PC go to http://192.168.1.1/
Then go to Settings>Advanced>Cellular
You should be able to edit the APN from there.
I am using the APN "broadband" and still get 5G on the AT&T network. You can also try "nrbroadband" though. They both seem to do the same thing on my router.
Also, make sure you are doing the APN Name as "ATT NRBroadband", and the actual APN is just "nrbroadband".- d4bbottAspirant
