FCB90's avatar
FCB90
Star
Apr 16, 2019
MR1100-100NAS no B20, NO SCC Carrier aggregation
Hello,
I am using the MR1100-100NAS device.
Firmware:
MR1100-100NAS_23113828_NTG9x50C_12.05.05.00_00_GenericNA_01.02 (newest).
The device does not support the B20 frequency, the aggregation is also not working -
AT!GSTATUS? command shows PCC only, no Secondary Component Carriers (SCC).
Of course, carrier aggregation is supported by other devices in this place so it's the problem with NETGEAR's device.
Reset of the device does nothing in this case.
NETGEAR's technical department, please help me to solve the problem.
  • Also adding second screenshot showing aggregation that just doesn't work.
      • FCB90's avatar
        FCB90
        Star
        Thank You for your answers.
        B1+B3+B7 should be aggregated and it's fully supported by BTS (checked with few other devices with the same SIM) - again, it's not problem with SIM, BTS or ISP.
        None of aggregation is working, 2CA too.
        NETGEAR'S Support, could You please tell me if aggregation on my device can be somehow blocked?
        MR1100-100NAS should support also B20, it's officially confirmed by NETGEAR - I've checked and it's not so it seems to be an critical bug in modem's firmware.
        Without aggregation the device is almost useless in normal conditions.
    • W1lliam's avatar
      W1lliam
      Virtuoso
      it seems this unit does not support B20,  from the first screen capture, you might need to check on specsheet from the vendor for 100NAS. As for aggregation, it would be depending on the carrier if they do support aggregation.
      William
